Forums >> Revit Building >> Technical Support >> Casework Graphics
Mon, Jul 27, 2009 at 7:12:02 PM | Casework Graphics
astew426
Hello All,
 I am having an issue with a few casework families that I have inserted into my project, and all of them seem to be above the crop range.  Here's the issue: in plan view, when the casework is placed up against a wall, sitting on the floor, the normally thick black line that defines the cut wall is shown as a thin line behind the casework.  Is there way to avoid that thin line?  I want the thick line to have a nice, continuous appearance.  Any suggestions?
Thanks, Alex.
Tue, Jul 28, 2009 at 7:06:22 AM | Casework Graphics
This is a problem in Revit.  When you have two lines in the same place, which one governs.  In your case, the casework line is thinner than the wall line and overwrites part of it.  Is this a 2D or 3D family.  If it is a 2D and has a masking region, look at the linework of the region.
Tue, Jul 28, 2009 at 7:02:56 PM | Casework Graphics
astew426
I figured it was a program issue, and no, the casework is 3-D. Pulling it off of the wall was the only solution I could find to correct the problem graphically, but that of course leaves you with an incorrect drawing.  If anyone else comes up with a solution, please let me know.  Thanks for the thoughts though WW.
Thu, Aug 18, 2011 at 3:53:04 PM | Casework Graphics
palladio1234
5 Stars: 3 Votes
Anymore come of this? I have this problem in pretty much every floor plan revit 2012 creates.
Phantom Casework
Tue, Aug 28, 2012 at 12:25:48 PM
Casework below in-place component won't show - R09
Fri, Dec 4, 2009 at 11:50:12 AM
Casework below countertop not visible.
Wed, Jan 27, 2010 at 2:16:58 PM
Capturing room number and name data for casework, furniture, etc.
Tue, Sep 20, 2005 at 8:45:55 AM
Lower casework showing through when touching counter?
Wed, Mar 6, 2013 at 9:38:23 AM
Page generation time: 1.7361
