59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Revit 2010-Dimensioning
Mon, Jul 27, 2009 at 10:46:46 AM | Revit 2010-Dimensioning
KJoshi
Hi
In Revit 2009, the wall faces used to highlight while dimensioning when we hover over them. Why don't they highlight for me in Revit 2010? In snap options under settings there's no option for snapping the dimensions to wall faces.
Please help
Thanks
Mon, Jul 27, 2009 at 1:12:25 PM | Revit 2010-Dimensioning
4 Stars: 203 Votes
Did you use the TAB key to select that?
Mon, Jul 27, 2009 at 2:07:46 PM | Revit 2010-Dimensioning
KJoshi
When I hit 'tab key' it gives me a ping sound and nothing on drawing area. The status bar reads "select references;then click in empty space to place dimension. Press spacebar to toggle between horizontal and vertical"
And in order to enter 'wall face' as reference, there is no wall face 'snap' option under settings.
Thank you
Mon, Jul 27, 2009 at 2:17:30 PM | Revit 2010-Dimensioning
4 Stars: 203 Votes
I don't know what are you doing wrong, in Manage>Settings>temporary dimensions select "faces" then if you need (and you do) select the work plane you want and dimension...
Mon, Jul 27, 2009 at 3:12:09 PM | Revit 2010-Dimensioning
KJoshi
Thank you
Mon, Jul 27, 2009 at 3:26:23 PM | Revit 2010-Dimensioning
KJoshi
 I did change the temporary dimension settings like you showed.But still not seeing the highlights on wall faces.
I wasn't clear before; I am doing permanent dimensions from menu: Annotations-Linear
Thank you
Wed, Jan 20, 2010 at 10:47:17 AM | Revit 2010-Dimensioning
mattburr20
Bringing this thread back to life!  I belive I had your same problem so I found an answer on another forum.  "The Aligned dimension is what you want to use to get the standard behavior you are used to. In 2009 the default was "aligned" and it was set on the options bar. In 2010 the user can pick which dimension they want directly form the ribbon. I would say using "aligned" wil do what you want 90% of the time."
Hope this helps!
Need help dimensioning this wall!
Sat, Jul 25, 2009 at 10:56:27 PM
Dimensioning 3D Views - 2010
Tue, Mar 30, 2010 at 1:49:49 AM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:56 PM
can't dimension this wall
Sat, Jul 25, 2009 at 11:06:28 AM
Revit 2008 - Dimensioning Curtain Wall
Tue, Feb 19, 2008 at 5:26:47 PM
Page generation time: 3.3237
