58 Users Online (57 Members):
Forums >> Revit Systems >> Technical Support >> Light switches not showing on floor plan
6 Posts No Rating |
Revit MEP 2010. I placed light switches on my floor plan and now I can see them. They show up on my sections though. I've changed the cut plane and viewing range but nothing seems to work. I'm only having this issue on my first floor plan.
I don't work with MEP and i can't see images of what are you seeing but did you check in that "first floor plan" if you have the view in "Coarse/Medium or Fine mode"??? or in VG if you turned OFF that Category?
6 Posts No Rating |
That level is on. Changing it from coarse to fine didn't do anything.
3 Posts No Rating |
try adjusting the elevation of the device in the properties before you place it..
hope this works!!
![coreed Avatar](user_avatar/14568.jpg)
by default light switches are above the cut plane. you will have to raise the cut plane to see the light switches
Edited on: Fri, Apr 29, 2011 at 1:51:10 PM
3 Posts No Rating |
even you try to change the cut plane it might not work..the default elevation of the device was 13' in my computer so I had to adjust the elevation to reasonable height..
Thanks..
Thanks..
who would put a light switch at 13'. you might want to fix that family.
3 Posts No Rating |
Have no clue but it was default on my PC.. just tought patrickj75 might have the same problem since he has already tried to change the cut plane settings..
peace!!
Floor plan showing ceiling fixtures and wiring to switches |
Wed, Feb 18, 2009 at 2:49:44 AM
light wiring in architectural floor plan |
Mon, Mar 6, 2017 at 9:26:58 AM
Reflected Ceiling Plans not showing in Electrical Plans |
Wed, May 4, 2011 at 1:19:05 PM
Simple Light with Multiple Switches |
Thu, Jul 19, 2018 at 7:34:17 AM
Light switches |
Mon, Sep 22, 2014 at 1:04:57 PM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
