68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Opening 2008 file in 2009 causes "Unrecoverable error" crash
Sun, Jul 26, 2009 at 2:27:31 AM | Opening 2008 file in 2009 causes "Unrecoverable error" crash
EssG
Hi,
Every time I try to open a completed project that was created in Revit Arch 2008 in  Revit Arch 2009 I get a "Unrecoverable error" message at the 75% stage, and the program crashes.
I have tried to "import/link" it into a 2009 file, to "Audit" while opening and still no go. A much earlier copy of the file have "upgraded" fine. I no longer have access to the 2008 version as I only had it at college and have now graduated, so I cant do any "cleaning up" in 2008. Any suggestions will be much appreciated.
Mon, Jul 27, 2009 at 11:41:56 AM | Opening 2008 file in 2009 causes "Unrecoverable error" crash
It sounds like you don't have enough memory to upgrade this project.  How large is the project?  Does it have links in it?  What are the specs of the system you are on... especially memory?
Tue, Jul 28, 2009 at 1:21:58 AM | Opening 2008 file in 2009 causes "Unrecoverable error" crash
EssG
Hi,
 Core 2 duo 1.86GHz, 4 G ram, Project size 30.8MB, no links.
Have just downloaded the  web update 3 service pack and will try again agter installing it
Thanks
Tue, Jul 28, 2009 at 1:36:33 AM | Opening 2008 file in 2009 causes "Unrecoverable error" crash
EssG
Ok that worked...file now converted.
Thanks
Revit 2008 - Unrecoverable Error when Opening Program
Mon, Mar 24, 2008 at 11:14:57 PM
revit crash
Thu, Jun 20, 2019 at 8:42:53 AM
2008 file giving "circular chain of ref" error on 2009
Thu, Apr 24, 2008 at 11:20:20 AM
2010 seems to crash my computer alot more
Fri, Jul 24, 2009 at 11:56:58 AM
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR
Thu, May 12, 2016 at 7:57:15 AM
Page generation time: 1.2908
