67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Dimensions style
![5 Stars: 2 Votes](/images/stars_5.gif) |
Hi again, I have two questions:
Talking about dimensions:
First: I have been trying to configure a dimension style in which the value appears over the line, at its middle point but i have not achieved it.
Second: I would like to have a dimension style in which there was no line but just the value, again I was defeated by Revit: I didn't get it.
Can you help me?
Thanks in advance.
AFAIK,
These options are not possible. Add to the wishlist...
Thanks for your quickly response (as always).
I have included the requests to the Wishlist as you suggested.
http://revitcity.com/forums.php?action=viewthread&thread_id=1728
Is it possible to turn off dimensions by style? Working on a remodel and have to draw up the existing plan from scratch. I made a dimension style called correct for dimensions I know are correct, and a style called needs checked for dimensions that need to be verified again in the field. Would like to shut off the correct dimensions so I can print a copy of the floor plan to go do the second field verification. Is this possible?
I ALWAYS FIND THE ANSWER AFTER I POST THE QUESTION! Here it is if anyone is looking:
<workaround>Select the dimensions you wish to hide, save a selection set. Go to visibility graphics, filter tab > add....your named selection set will be available as a filter.</workaround>
Edited on: Tue, Oct 6, 2020 at 2:20:46 PM
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
You could also just select the "Correct" dimension style, right click --> Select All Instances --> Visible in View or In Project --> right click again --> Hide in View --> Elements or right click again, at the bottom of the Revit window where scale and detail level and other buttons are you can click the Sunglasses and temporary hide the elements.
Then you can print your drwings and turn everythign back on when done.
Stacked Walls and Dimensions |
Fri, May 3, 2013 at 11:46:23 AM
Text width for dimensions... |
Tue, Aug 7, 2007 at 7:55:42 AM
Temp Dimensions |
Mon, Sep 23, 2013 at 9:48:54 AM
Dimensions style |
Fri, Feb 25, 2011 at 9:46:02 AM
DWG Conversion Dimension Style |
Mon, May 10, 2010 at 8:28:13 AM
Members: | 2016934 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
