62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
Fri, Jul 24, 2009 at 3:43:21 PM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
adaa
Revit 2010--I just started using the student version of the program and it's been glitchy! For some reason I can draw walls in plan but they DO NOT SHOW UP IN 3D (this is the problem). I attached a file for viewing... I think it may be because I made a diagonal reference in 3D that's but now I can't delete that reference plane. I have no idea what to do and I really need a solution to this problem so I can finish my project!
Edited on: Sun, Jul 26, 2009 at 2:31:58 PM
Fri, Jul 24, 2009 at 4:01:50 PM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"I attached a file for viewing".....Nope!!
Fri, Jul 24, 2009 at 4:55:06 PM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
could it be that your phase filter in 3D mode isn't set to show the phase you're drawing in plan?
Sat, Jul 25, 2009 at 11:24:32 AM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
tim123
4 Stars: 19 Votes
It could be a number of reasons, but I don't think that from that you can conclude that Revit is either lame or glitchy.
Try:
Walls are switched off in the 3d view, or the category is temporarily hidden
There is something that is far from the wall (outside the crop region in plan, perhaps a CAD insert) so that you're not zooming to the right place, or it's so far away that you can't see it
It's in a workset that is switched off in the view
As mentioned, it's in a different phase
Sat, Jul 25, 2009 at 12:59:51 PM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Hi adda,
REVIT is most definately not glitchy.
You need to understand a few things before you dive in because REVIT is a very sophisticated 3D parametric design program and what is happeing is happening for good reason.
As tim indicated the walls may not be showing up for any number of reasons.
Make sure you do a 'zoom to fit' to start with, in the 3D view.
My guess is you have 'cropped' the 3D view (outside the extents of the walls) and then turned off the crop region outline. To check this possibility turn 'off' view cropping then do a 'zoom to fit'.(see attached image).
This could also be casued by:
The view 'discipline'
Temporary Hiding
Visibility graphics / override
Phases
Probably a few more......
Upload the file and we'll be sure to tell you.
Edited on: Sat, Jul 25, 2009 at 1:06:20 PM
Sun, Jul 26, 2009 at 2:23:25 PM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
adaa
I attached the file under 'file attachments'...it does not appear. How can I make it smaller?
Edited on: Sun, Jul 26, 2009 at 2:32:54 PM
Sun, Jul 26, 2009 at 2:31:34 PM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Nope, not yet.....make sure it doesn't have more than 2mb....
Sun, Jul 26, 2009 at 2:36:16 PM | erland73
adaa
Quoting erland73 from 2009-07-26 14:31:33
"Nope, not yet.....make sure it doesn't have more than 2mb...."
Is it okay that I email the file to you? Thanks.
Sun, Jul 26, 2009 at 3:00:24 PM | PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =(
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sure. dgregoire@cadclips.com
Work Plane issue....
Fri, Apr 18, 2008 at 11:50:58 AM
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:43 PM
Disassociating work plane
Thu, Apr 21, 2016 at 11:10:29 AM
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:50 PM
14
Floor & Work Plane Error Message
Thu, May 4, 2017 at 8:01:03 PM
Page generation time: 1.2915
