130 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Line Patterns
Wed, Aug 3, 2005 at 4:43:33 PM | Line Patterns
sfrancis
Is it possible to make a line pattern consisting of letters such as a Gas Line or a Fence Line or a Water Line, etc.....? example: ----X----X----X
Wed, Aug 3, 2005 at 6:19:51 PM | RE: Line Patterns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No, but its on the wish list. Current method is to use a repeating detail component.
Thu, Aug 4, 2005 at 9:40:20 AM | RE: Line Patterns
sfrancis
Thanks for the info....Do you know if there is a way to add details to your door or window families so that when you cut a section through them, the details will show in the section view? That would eliminate having to detail them in section view (wish list?)
Thu, Aug 4, 2005 at 4:30:31 PM | RE: Line Patterns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can definitely do that. You need to embed detail components in the appropriate locations in the family then set them to only display at fine scales...
Fri, Aug 5, 2005 at 11:19:13 AM | RE: Line Patterns
sfrancis
Thanks that seemed to work, except for 1 thing. I am putting an aluminum frame detail in the head of a window, and I constrained it to the glass of the window. When I do a detail cut of that window, the detail is in the center of the frame and doesn't stay consistant with the glass. Any ideas?
Fri, Aug 5, 2005 at 7:59:34 PM | RE: Line Patterns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make your detail parametric and link the parameters to the window family...
Tue, Aug 9, 2005 at 3:08:31 PM | RE: Line Patterns
sfrancis
OK...I'm stuck. I spent the day yesterday working on your answer, but to no avail. Could you explain (or lead me to where I can find it) how to make it parametric and link it to the family? Thanks.
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:06 AM
Tile Patterns, not line patterns
Fri, May 17, 2019 at 9:29:05 AM
Deleting multiple line patterns...
Mon, Nov 2, 2009 at 11:18:31 AM
Line Patterns - Too restrictive
Fri, Oct 7, 2005 at 4:50:39 PM
How to add new graphics to line patterns rather then just using dashes and dots?
Tue, Mar 11, 2008 at 5:11:36 PM
Page generation time: 1.0692
