65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Whats the best way to draw and modify simple alum. storefront window systems
Tue, Mar 2, 2004 at 12:04:46 AM | Whats the best way to draw and modify simple alum. storefront window systems?
bayou66
3 Stars: 1 Votes
I am wondering for a typical 2"x4" or 2"x 4 1/2" aluminum and glass window system; is it best to create your own Family or is there a good, modifiable Family suitable for using, making changes easy, etc...? Post edited on 2004-03-02 00:13:47
Tue, Mar 2, 2004 at 12:13:20 AM | RE: Whats the best way to draw and modify simple alum. storefront window systems
hjacobs
admin
hjacobs Avatar
3.5 Stars: 16 Votes
Use the curtain wall tool for this...
Hiroshi Jacobs
Tue, Mar 2, 2004 at 12:14:34 AM | RE: Whats the best way to draw and modify simple alum. storefront window systems
bayou66
3 Stars: 1 Votes
I got that - but then what about inserting the door - will the one that you uploaded work ?
Tue, Mar 2, 2004 at 9:27:46 AM | RE: Whats the best way to draw and modify simple alum. storefront window systems
hjacobs
admin
hjacobs Avatar
3.5 Stars: 16 Votes
there are 3 components to curtain wall systems...the curtain grid (invisible lines determining the location of the grid) - mullions (the actuall mullion pieces) and panels (the objects between mullions) Panels can be glass, solid, whatever...including doors. Select the panel where you want your door (be sure to select the panel instead of the grid or mullion) and change it's type from System Panel or Glazed Panel to a curtain wall door type. Voila! You can change its size by changing the location of the curtain grid lines.
Hiroshi Jacobs
Tue, Mar 2, 2004 at 4:12:05 PM | RE: Whats the best way to draw and modify simple alum. storefront window systems
RAFE
Quoting hjacobs - 2004-03-02 09:27:46
"there are 3 components to curtain wall systems...the curtain grid (invisible lines determining the location of the grid) - mullions (the actuall mullion pieces) and panels (the objects between mullions) Panels can be glass, solid, whatever...including doors. Select the panel where you want your door (be sure to select the panel instead of the grid or mullion) and change it's type from System Panel or Glazed Panel to a curtain wall door type. Voila! You can change its size by changing the location of the curtain grid lines."
If you want to alter the actual panel, open the family file and change it - save and reload that family into your project. We have done this when say a door in a curtain wall has different sized stiles, and we wanted a pull handle to be on the door in the curtain wall....
Post edited on 2005-06-13 04:16:08
Wed, Mar 3, 2004 at 2:49:53 PM | RE: Whats the best way to draw and modify simple alum. storefront window systems
bayou66
3 Stars: 1 Votes
Thanks to you guys ... great information - I am going to try it out. I also cant seem to trim a grid line - for creating different mullion work. Any thoughts on this ?
Wed, Mar 3, 2004 at 3:12:10 PM | RE: Whats the best way to draw and modify simple alum. storefront window systems
hjacobs
admin
hjacobs Avatar
3.5 Stars: 16 Votes
when you select a grid line, there will be a button at the top called Add or Remove Segments click it and then click the curtain grid segment you want to get rid of.
Hiroshi Jacobs
Fri, Mar 5, 2004 at 7:41:41 PM | RE: Whats the best way to draw and modify simple alum. storefront window systems
bayou66
3 Stars: 1 Votes
dang you guys are good ! Thanks a bunch... I am printing and drawing...
storefront glass - doors and windows
Mon, Oct 24, 2005 at 5:03:17 PM
window / storefront schedule,
Thu, Sep 10, 2009 at 1:02:39 PM
Window Vs. Curtainwall - Storefront
Tue, Jul 3, 2007 at 1:49:16 PM
modify issue
Sun, Apr 1, 2018 at 8:34:55 AM
Storefront windows in the window schedule
Tue, May 21, 2013 at 3:25:44 AM
Page generation time: 1.0616
