69 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Structural link showing colored lines - please help!
Thu, Jul 23, 2009 at 10:14:09 AM | Structural link showing colored lines - please help!
simonk99
My structural link shows blue circles at the base of each column, a brown line at each floor level, and orange lines at each bracing member.  I've tried every combo of checking and unchecking in the custom link tabs, but i can't separate the colored lines from the structural members.  My structural engineer doesn't even know he's drawing them.
Thu, Jul 23, 2009 at 11:52:10 AM | Structural link showing colored lines - please help!
structuresguy
It sounds like the analytical lines are turned on for the structural components.  Load up the visibility graphics, then for each structural component type expand the list, and then uncheck "analytical lines".  The colored lines should go away then.
Thu, Jul 23, 2009 at 12:03:18 PM | Structural link showing colored lines - please help!
simonk99
That doesn't work.  If I uncheck the category STRUCTURAL FRAMING then both the orange line and framing dissapear.  If I keep the category checked, but uncheck ALL of the sub-categories, then my framing is hidden, but the orange line remains!
Thu, Jul 23, 2009 at 1:05:05 PM | Structural link showing colored lines - please help!
Change the VG settings in the VG under the Revit links then custom settings for the VG for the link.
Thu, Jul 23, 2009 at 1:29:08 PM | Structural link showing colored lines - please help!
simonk99
That's what we were talking about.  That doesn't work.
Thu, Jul 23, 2009 at 2:18:34 PM | Structural link showing colored lines - please help!
simonk99
Here's the answer to my own question:
Under Revit Links VG Overrides:
  • Switch to custom
  • Then change linked view to none
  • Then change view range to by host
Regarding "Analytical Models" ...that appears to be a category in Revit 2009 that no longer appears in version 2010...
Thu, Dec 2, 2010 at 2:50:06 PM | Structural link showing colored lines - please help!
quinn
Here is the the percise answer.  Go to VG and check the box at the bottom of your categories titled show categories from all disciplines, then expand structural columns category and turn off analytical model subcategory and all those circles will go away.
Thu, Dec 2, 2010 at 3:06:14 PM | Structural link showing colored lines - please help!
quinn, that is an answer that will work for analytical lines, but linked models ofetn have other elements that need to be controlled.  One such item is levels and grids in the linked file.  That is why I prefer to control the linked file through the VG settings / linked files / tab and adjusting the VG of the linked file there.
Thu, Dec 2, 2010 at 3:21:30 PM | Structural link showing colored lines - please help!
quinn
100% agree, there are many ways to control the view settings thru linked VG or Host View etc... the main goal for me was to inform people of how to get access to those hidden subcategories that will give them the ability to turn off very specific objects within an element, to focus on the OP problem in this thread to find a solution for the analytical lines from structural columns.
Thu, Dec 2, 2010 at 3:27:08 PM | Structural link showing colored lines - please help!
gdoherty0102
3 Stars: 2 Votes
It would be great if we could turn off linked annotations in every view by default.  I know you can just not bring in that workset, but we still need the grids and levels in one coordination view just to keep track of everything.
Thu, Dec 2, 2010 at 3:32:37 PM | Structural link showing colored lines - please help!
#11
quinn
What we do is create open up our veiw templates and have the linked file annotation category turned off by default so as we create new views they just stay off. We also created a specific view template for linked files as well that if a view already has rthem showing we just apply that view template and bam all gone. View templates are great for spedding up filtering like dimension plans especially.
Linked model reference lines showing
Fri, Feb 10, 2012 at 9:29:00 AM
Structural Analysis lines showing up
Tue, Jun 27, 2006 at 6:38:14 AM
Colored Lines for presentation
Tue, Oct 8, 2013 at 7:09:19 AM
Revit Structural 3 analysis lines showing up.
Wed, Jul 12, 2006 at 6:07:57 PM
Revit link not showing except in 3D
Thu, Mar 6, 2008 at 9:01:25 AM
Page generation time: 2.1615
