27 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall visual and door visual
Thu, Jul 23, 2009 at 10:08:42 AM | wall visual and door visual
jdivina
2 problems but both pertaining to the same idea.
 1.  in the project an existing wall has a certain shade to it.  but in the elevations i want it to show a certain colour.  without changing the view to coarse and overriding it because i wanna see the joists as joists not as single lines.  how would i be able to do that.
2. doors- im trying to make the doors green like say a certain material that is the color sage green and through the element properties i am having trouble changing them just because there is no option to.  they already have materials on there that are in the pulldown menu but not the ones that are on the material list but abbreviated ones that aren't even in the materials list.  how would i change the material?
JD
Thu, Jul 23, 2009 at 10:20:13 AM | wall visual and door visual
jdivina
k the problem with the doors are fixed.
it's basically going into your vg and just overriding the doors to that colour.
(should of saw that one, mind is blank right now haha)
JD
Thu, Jul 23, 2009 at 11:46:39 AM | wall visual and door visual
jdivina
ok part 1 for the walls worked thanks to asianfear.
u right click on the element u want to show different t
then override graphics in view then
change the surface
JD
Revit Link - Two visual styles displayed in one view
Mon, Nov 12, 2012 at 5:37:21 AM
two different visual styles in one view
Tue, Feb 5, 2013 at 8:00:13 AM
ovverride graphics
Wed, May 21, 2008 at 6:10:26 PM
View Range visual
Thu, Dec 16, 2010 at 2:57:32 PM
Color in Hidden Line Visual Style??
Mon, Oct 19, 2015 at 12:16:53 PM
Page generation time: 7.4240
