81 Users Online (80 Members):
Forums >> Revit Structure >> Technical Support >> 1/8" TEXT HEIGHT
2 Posts No Rating |
It seems the default out of the box text height for beam tags, section cuts etc is 3/32" text. our company standard is 1/8" text, how do I change these to read as 1/8" text without editing all of the rfa files?
I think you will want to change the families to assure that the graphics works with the larger text.
2 Posts No Rating |
What is the industry standard for text height on structural construction documents, I have always believed this to be 1/8", but this software is setup at 3/32"? What is everyone else doing, using the out of the box 3/32" text heights?
We use 3/32 and I believe that most use 3/32.... The old hand drawn standard was 1/8.
head height of window |
Thu, Nov 3, 2005 at 5:19:14 PM
I can't see "Height" parameter value of Wall or Currtain Wall Schedule? |
Thu, Apr 27, 2017 at 2:04:39 AM
text title block from parameters out of a family |
Wed, Apr 12, 2006 at 7:29:02 AM
Lettering Set up |
Fri, Oct 14, 2005 at 3:55:14 AM
What's up with the tezt "size"????? [ 1 2 ] |
Tue, Aug 19, 2008 at 10:16:25 AM
25
Members: | 2017148 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
