61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 7.22.09: Family Materials, Subcategories
Wed, Jul 22, 2009 at 10:46:53 AM | Revit TotD – 7.22.09: Family Materials, Subcategories
rkitect
rkitect Avatar
4 Stars: 29 Votes
Yesterday I showed you how to directly apply materials to objects in your families and the reasons to do such a thing.  Today I’m going to do the same thing, except we’ll be talking about the Subcategory approach.
Create the Subcategory:
  1. (In the family creator) Manage Ribbon > Settings > Object Styles
  2. New in the Modify Subcategories section
  3. Name the subcategory and be sure it is being created in the correct Category (some family types have multiple Category Controls).
  4. You can start to see in this dialog why subcategories may be more beneficial than direct application of materials.
Apply the Subcategory:
  1. Select the object(s) to be added to the subcategory.
  2. Element Properties.
  3. Select the subcategory that the object belongs to in the combobox.
When to use this method:
  1. When all instances of this object need to appear the same in rendering.
  2. When you need to control line weights and visibilities of different objects in the family from the project side
Changing the material (In project):
  1. Under Manage Ribbon > Settings > Object Styles
  2. Look for the category that the family is in and expand that branch.
  3. Change the material of the Subcategory that you need to modify for that family.
In my opinion, you should ALWAYS use this method over direct application of the material since it allows you to control so many more aspects of the objects in your family (like line weights, visibility, etc).  Note that we no longer have the duplicate issue with Subcategories that we had with the multiple Materials.  If you have two families that are in the same category with similar Subcategories, they will all be controlled under one Subcategory control in the project.  This allows you to have an entire set of furniture (for instance) that can have matching materials by use of a single Subcategory, so be aware of what you are naming your subcategories.  There is still one more method to look at and that is the Instance Method of applying materials to families.  So join us tomorrow for another Revit TotD as we wrap up this series on family materials!
As always, you can enjoy this tip in its entirety at: http://revittotd.com/07/561
-Carl
revit_arch_09_cert_pro_rgb
Fri, Sep 11, 2009 at 9:08:12 AM | Revit TotD – 7.22.09: Family Materials, Subcategories
psmeisje
I recently started using this method and i also prefer it.
I wanted to add that you can also use subcategories on lines (model and detail lines) in your families. The subcategory appears as a line style you can select.
Only problem is I can't get this method to work for masking regions in families.
Edited on: Fri, Sep 11, 2009 at 9:08:53 AM
Fri, Sep 11, 2009 at 10:23:06 AM | Revit TotD – 7.22.09: Family Materials, Subcategories
JFK64
I too have tried to masking regions in families. I believe that a masking region in a family is view oriented and thus object styles don't seem to apply to it.
John
Revit TotD – 7.21.09: Assigning Family Materials, the Direct Approach
Tue, Jul 21, 2009 at 10:30:24 AM
Revit TotD – 7.23.09: Family Materials, Parameter Application
Thu, Jul 23, 2009 at 8:46:57 AM
Revit TotD – 7.9.09: Glowing Sign, Self-Illumination Based Materials
Thu, Jul 9, 2009 at 2:20:36 PM
Subcategories for export
Wed, Jul 26, 2006 at 12:46:16 AM
Cannot override newly created subcategories from linked model.
Fri, May 17, 2013 at 1:44:14 PM
Page generation time: 2.2740
