79 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Grid Dimension shown views
24 Posts No Rating |
Hi I have a grid which is currently dimensioned in one plan. Is there a way of applying this dimension to all plans without having to copy them across? As dimensions are a special element like the levels, I would assume there could be a way to show the dimensions for the grid whitout having to copy them around. But maybe this is one for the wishlist. Thanks
Open the plan with your dimensions and select them all - copy to clipboard ... open your other plans and paste same place. Read your HERLP - these topics : Copying Elements to the Clipboard Pasting Elements from the Clipboard Pasting Aligned Elements
Thanks HUB I always uses the help file before posting an issue but thanks for the reminder. I had hoped that there was another way than using the copy/paste command, as grid dimensions has to be shown every time the grid is shown. Therefore it made sense if there was a different way than with ordinary dimensioning.
workaround for dimension partially of view so not shown |
Tue, Apr 26, 2016 at 10:28:58 AM
Grid Dimensioning |
Tue, Jun 3, 2008 at 5:49:38 PM
Dimension or Detail Component? |
Mon, Nov 18, 2013 at 3:24:16 PM
Dimensioning tolerances to use align dimension with grid lines ? |
Tue, Feb 9, 2016 at 11:18:30 AM
Different Grid Bubble for different scale views? |
Thu, Dec 12, 2013 at 5:42:13 AM
Members: | 2030725 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
