69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> actually showing low voltage wiring in the model, is it possible?
Mon, Jul 20, 2009 at 1:28:21 PM | actually showing low voltage wiring in the model, is it possible?
jcrocco
3 Stars: 1 Votes
I  know that Revit MEP has allot to be desired in regards to the electrical aspect, but I was wondering if anyone has attempted to actually show in the model actual low voltage wiring.
Would it even be possible to show a 1/4" diameter wire/conduit/pipe/etc within the model and show it as low voltage wire from one point to another?
A customer of ours is interested in being able to account for these in the model.  Can a family be made that could be one continuous piece from one end to the other, going up, around, and down as needed so that when selected, it would show the path of travel and information added to it in regards to what it connect to and from where?
Any thoughts or ideas would be appreciated.
Mon, Jul 20, 2009 at 9:34:59 PM | actually showing low voltage wiring in the model, is it possible?
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
If you have found out already, best way to do this is to use piping, I have created conduit fittings for a specific pipe type.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Wed, Jul 22, 2009 at 3:16:03 PM | actually showing low voltage wiring in the model, is it possible?
jcrocco
3 Stars: 1 Votes
Is there a way to make a flexible pipe that can be flexed withn the model?
The problem with piping is that each bend is a fitting.  I can make 1/4" diameter pipes and fittings, but if I want to make a lengthy run of pipe (wire) as a solid selectable object, with data attached to it, can it be done?
Low voltage wiring in Revit MEP
Fri, Apr 23, 2010 at 4:34:27 PM
Revit for Low Voltage Structured Cabling
Tue, Jan 13, 2009 at 8:17:18 PM
Electrical wiring
Wed, Nov 12, 2008 at 4:22:37 AM
error: Voltage for the Circuit is out of range for the Line to Ground Voltage...
Sun, Sep 30, 2012 at 12:16:32 PM
Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
Wed, Dec 7, 2011 at 8:54:54 AM
Page generation time: 1.6373
