27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How do I model a corkscrew? Revit2010
Sun, Jul 19, 2009 at 2:43:24 AM | How do I model a corkscrew? Revit2010
LSMS
The reason I am asking is because I need to model one, but also because modeling in revit is based on workplanes and I am having difficulties creating paths that start on one workplane and move to another.
Mon, Jul 20, 2009 at 12:36:12 PM | How do I model a corkscrew? Revit2010
MARS1276
1 Stars: 1 Votes
I too have wondered something similar.  Should I need to model a screw complete with threads and lengths/sizes; how can it be done?
Mon, Jul 20, 2009 at 1:23:47 PM | How do I model a corkscrew? Revit2010
need4mospd
Use a swept blend. I belive the easiest way to do it is to do 180 degrees at a time, and just mirror it over and up to complete the loop. Then just copy it up however many times you need it. The reason for it being 180 degrees is that it won't let you go the full 360.
So your path would be an arc, profile 1 is at the ground level, profile 2 is half way up and on the other side.
Hope that helps.
Mon, Jul 20, 2009 at 3:46:07 PM | How do I model a corkscrew? Revit2010
LSMS
Thanks for the reply, that's exactly how I managed to do it.
I used a swept blend with offset profiles at 180 degrees.
Though you might get the result you're looking for, you can't use join geometry so you end up with a cutline every 180 degrees.
I was hoping Revit2010 had a newer approach to freeform modeling.
In the "sweep" command thumbnail picture they did run the same sweep on two workplanes...
Mon, Jul 20, 2009 at 10:40:05 PM | How do I model a corkscrew? Revit2010
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In 2010, too easy!!
Just use a spline through points!!
Regards,
Chris.
Tue, Jul 21, 2009 at 3:18:54 AM | How do I model a corkscrew? Revit2010
LSMS
Thanks, I forgot about that, I even saw a tutorial on youtube:
http://www.youtube.com/watch?v=-4tK1gjgNt8
Wed, Oct 9, 2013 at 6:30:45 PM | How do I model a corkscrew? Revit2010
JustBrev
Mr Spot,
how can i avoid the "folding" of the spline at the start and end
thanks
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Revit2010 Rendering Crash
Sat, Jul 10, 2010 at 1:25:58 PM
rendering in REVIT2010
Mon, Jul 20, 2009 at 7:12:46 PM
how could I add a slope in my roof by extrusion? Revit2010 [ 1 2 ]
Thu, Oct 22, 2009 at 11:12:47 AM
19
default file locations
Mon, Jan 11, 2010 at 5:44:30 PM
Page generation time: 9.5596
