103 Users Online (101 Members):
Forums >> Community >> Newbies >> Night Rendering with artificial lighting?
6 Posts No Rating |
If I render with artificial only, my lights look great but as soon as I switch on the sun, which is set to dusk, my lights loose all their power. How can I accurately render with both? Im playing around with the 'adjust exposure' dialogue, but no luck yet. Thanks
![erland73 Avatar](user_avatar/39932.jpg)
![4.5 Stars: 85 Votes](/images/stars_4.5.gif) |
You have to increase the wattage of your lights i.e. from 30w to 300w....and render with Interior (or Exterior):Sun and Artficial lights
“Learning never exhausts the mind.” — Leonardo Da Vinci
6 Posts No Rating |
Ok, I had stumbled upon that solution earlier but was unsure if it was the best way. Is there any way to select all of my lights and increase them all at the same time or do I manually have to select every light? Most of them are neither wall nor ceiling based so it has been kinda tedious thus far.
When you pick in one light and change the properties, if they are in the SAME FAMILY of the others, when you change one you change ALL of them, if you have "Inserted" 2 or 3 families in the project, you only must to change 2 or 3 lights in the properties.... see in the HELP menu what is FAMILIES and how it works...
See the image attached to understand what Typhoon is telling you, then you could get somethig like this: http://www.revitcity.com/gallery.php?action=view&gallery_id=9775 http://www.revitcity.com/gallery.php?action=view&gallery_id=7205
External Lighting Night Scene |
Mon, Oct 26, 2009 at 2:09:22 AM
interior lighting for exterior rendering [ 1 2 ] |
Thu, Feb 11, 2016 at 2:03:04 PM
16
Renders with artificial lighting on result in high saturation and black patches |
Tue, Jun 21, 2016 at 7:29:28 PM
lighting scheme and artificial lights |
Mon, May 19, 2008 at 9:21:47 PM
Lighting Units not Rendering |
Mon, Nov 9, 2015 at 7:03:00 PM
14
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
