147 Users Online (146 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Construction Assembly Schedule
Tue, Aug 2, 2005 at 3:17:17 PM | Construction Assembly Schedule
ALTERit
I am trying to create a construction assembly schedule in revit. Is there a way to have a small section of wall in the schedule? I have tried cutting and pasting but it doesn't seem to work. Can you make the wall assembly plan detail parametric?
Tue, Aug 2, 2005 at 3:23:17 PM | RE: Construction Assembly Schedule
JoeDrevitO
Hey Alterit. Revit is able to do some beautifull things with construction assemblies. Create a new legend (view, new, legend). Open the drafting menu on the left and click "Legend Component" You can then place any of your walls, floors, roofs whatever in a plan or section view. You can edit the properties of the insert to change the sample length, and if you change the structure the wall will be updated automatically for you. Once you have placed it you can add studs, bricks and such using the repeating detail tool or detail components. Insulation is very easy just click and drag as much as you want. Sometimes I get pretty frustrated with Revit, but things like this make me just love it. Cheers!
Thu, Aug 4, 2005 at 7:33:54 PM | RE: Construction Assembly Schedule
ALTERit
Thanks D'RevitO Your the best!
Existing wall assembly visable in New Construction phase
Wed, Nov 2, 2011 at 5:49:10 PM
Wall Schedule showing Wall Assembly
Thu, Apr 29, 2010 at 1:26:28 PM
Assembly Schedule:Part List
Sat, Oct 29, 2011 at 2:32:39 AM
Revit 2008 MEP Energy modeling: Editability of construction assembly types
Mon, Sep 10, 2007 at 3:37:37 PM
Creating a Schedule showing all Assembly Codes
Tue, May 17, 2005 at 2:48:24 PM
Page generation time: 0.5587
