44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Moving dimension value
Fri, Jul 17, 2009 at 3:17:49 AM | Moving dimension value
neotropic
I have a problem with dimensions. I'm trying to move the dimension value to the center of the line, but I can't make it to center by itself.
I have tryied to search from the forums, but as I can see it, it seems to be impossible and I have to do it manually.
Fri, Jul 17, 2009 at 7:46:07 AM | Moving dimension value
Your question is not clear.  The text should normally center over the dimension line.  You can control how far it is above the dimension line by the text offset setting but I don't believe you can set the text to break the dimensio line.
Fri, Jul 17, 2009 at 8:26:12 AM | Moving dimension value
neotropic
Sorry that my question wasn't clear.
But actually that was the answer what I was looking for.
Now I know that it is not possible to put the text to the middle of the dimension line.
Thank you for your help
Edited on: Fri, Jul 17, 2009 at 8:27:37 AM
Fri, Jul 17, 2009 at 11:36:37 AM | Moving dimension value
JMedina
I have a question about moving revit model for a project I am drawing. It was not drawn in the true northing and easting coordinates in AutoCad. I now have the information of where each corner of the building should be located (northing and easting). How do I move the building with in the file so each corner of the building is aligned to the true northing and easting coordinates? This is a task that is easily accomplished in AutoCAD, but I cannot figure out how to do it in Revit.
Fri, Jul 17, 2009 at 11:42:15 AM | Moving dimension value
What REVIT?
This is much easier in 2010.  AUGI|AEC EDGE
There is a very good article in there on locating your project.
Fri, Jul 17, 2009 at 12:07:35 PM | Moving dimension value
JMedina
I am using Revit Arch. 2009 but I believe that my company also has 2010.
MOVING DIMENSION TEXT
Tue, May 1, 2007 at 4:05:43 AM
Dimension Measurement Verification
Mon, Jan 8, 2007 at 2:58:42 PM
temporary dimension disappearing when converting it to permanent dimension
Thu, Sep 14, 2017 at 9:48:31 AM
dimension value.
Tue, Nov 3, 2009 at 7:02:11 AM
Activate Dimension
Tue, Dec 13, 2011 at 12:53:45 PM
Page generation time: 0.3035
