Forums >> Revit Building >> Technical Support >> Enlarged Plan callouts disappear
79 Posts No Rating |
So, I've read a few threads about a similar issue in 2007 and 2008 builds. I'm working in 2009. My enlarged plan callouts have disappeared on my floor plan in level one, but in level 2 they are all visible. They are not hidden in view by element or by category, and in my visibility setting for annotations the callouts are turned on. I am able to place a new callout on the plan it and shows up fine, but all of my old enlarged plan callouts, again, are gone. Aybody have any idea what the heck is going on here and how to fix it? Thanks for your time.
----------------------------------- HuntFlo |
scratch that, figured it out. they were placed in an obscure for export only floor plan by an intern, so don't waste your time. thanks.
new problem. is it possible to copy over all the callouts from one plan to another?
If they are a real plan of the same area, they should show already. Otherwise, should you be using "Reference other view?"
Rotating details on sheets without rotating their callouts in plan |
Wed, Dec 10, 2008 at 5:28:38 PM
Copy Callouts from one plan to another |
Thu, Jul 16, 2009 at 12:44:35 PM
Are Callouts Vew Specific? |
Wed, May 12, 2010 at 3:56:07 PM
Plan Callouts have disappered. HELP! |
Wed, Oct 24, 2007 at 2:06:45 PM
callouts scope workaround? |
Thu, Oct 3, 2013 at 3:31:03 PM
Members: | 2114563 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
