27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> the ribbon
Wed, Jul 15, 2009 at 9:34:07 PM | the ribbon
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
it says you can expand the panels on the ribbon
by clicking the tiny pointer- that works- but
the tutorial says this:
"To keep a panel expanded, click the push pin icon
in the bottom-left corner of the expanded panel."
i can't find any "push pin" anywhere- does anyone
know what this means?
Thu, Jul 16, 2009 at 4:32:25 PM | the ribbon
pepsiqueen
pepsiqueen Avatar
if you have the panel in the ribbon, the push pin is there. if you have the panel floating somewhere outside the ribbon, there is no push pin. frustrating if you have plenty of space on a seconday monitor...
I'd rather be riding at whistler. or highland. thats good too.
Thu, Jul 16, 2009 at 10:59:45 PM | the ribbon
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
see my screenshot-
do you see a push pin anywhere?
also why do people keep talking about taking
the panels off the ribbon and putting then
on a separate monitor? have these people actually
tried that? do they know how big those panels
are and how many they could actually get on
a second monitor? not many..
Fri, Jul 17, 2009 at 10:48:05 AM | the ribbon
pepsiqueen
pepsiqueen Avatar
the only things that give you the pin option as far as i can see are dimension, tag, and room&area. See attached screenshow, where the dimension tack is visible, but if that panel was floating off the the right on the 2nd monitor, the tack does not appear.
Fri, Jul 17, 2009 at 10:51:46 AM | the ribbon
pepsiqueen
pepsiqueen Avatar
image will not upload for soem reason.
Fri, Jul 17, 2009 at 1:47:20 PM | the ribbon
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
yes thanks- it's only a few of the expandable panels that have the pins..
the tutorial don't say that..
as for the second monitor- as you can see- only a few of the panels
can go there- so why bother.. as for the browser- it can go on that
wasted space you have on either side of that building or only turn
it on when you need it..
with two monitors- that just means your head is working back and forth
instead of relaxing in one position..  so far the best i've found
is a single monitor at 1280 x 960.. see my attachment..
Fri, Jul 17, 2009 at 1:52:42 PM | the ribbon
Xaquin
1440x900!
what I wouldn't give for a classic menu option though
Fri, Jul 17, 2009 at 3:55:53 PM | the ribbon
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
Xaquin- i try to fight off thoughts of the classic UI..
but i believe it's true- the previous UI was like a ferrari-
where the new one is like a GMC utility vehicle..
but at least it does look modern- and that might
be important if clients look at your screen..
also there might be some kind of miracle for 2011.. lol
Fri, Jul 17, 2009 at 5:09:40 PM | the ribbon
pepsiqueen
pepsiqueen Avatar
the ribbon is a pain in the curse, too many clicks to get at info that used to be so close. and as for keyboard shortcuts, autodesk should make it easier to customize them, make them an option inside revit instead of fooling around in a TXT file. I could of sworn older versions you could edit the shortcuts from within the program, but i cant find anything of the sort in 2010. having to click on icons at all is a pain, personally i like a clean screen with nothing on it but the drawing.
Sat, Jul 18, 2009 at 12:50:24 AM | the ribbon
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
"clean screen with nothing on it but the drawing"
that was my idea three years ago and i found the
only solution to make that happen and i wish i would
have done it then.. but now i should still do it..
there is a device- and i don't remember the name
of it- but it's a thing that has many buttons that fit
your left hand that can be programmed and your
left hand never leaves this device and all the revit
commands and numbers can be done from that..
of course there is voice recognition if you like that..
windows 7 has top of the line voice recognition
built in..
something has to be done about this ribbon- i agree..
Wed, Jul 22, 2009 at 9:35:33 AM | the ribbon
#11
Xaquin
I think you may be talking about a Nostromo WYSIWYG.
I have one and LOVE it.  Took me about a week to get used to, but now I'm a million times faster using it over the keyboard.
Wed, Jul 22, 2009 at 10:48:29 AM | the ribbon
#12
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Xaquin,
Can you tell us more about your Nostromo? I usually use my left hand for my mouse but have injured my left wrist and am looking into alternative setups. Do the Nostromo reduce repeatitive movement? How difficult was it to program for Revit functions?
Fri, Jul 24, 2009 at 8:59:23 AM | the ribbon
#13
Xaquin
I hate to say it, but I mostly used it for quick keys in CAD.  I don't know too many shortcuts in Revit.  It doesn't aleviate repetitive movements as it remains stationary.  You just move your fingers.
this is the one I use:
(also, it's so easy to program =)
ribbon issues
Thu, Aug 27, 2015 at 10:14:04 AM
Ribbon for Revit
Sat, Aug 29, 2009 at 2:09:53 AM
Ribbon tabs 2011
Wed, Nov 23, 2011 at 2:08:46 PM
Ribbon Windows
Thu, Jan 19, 2006 at 4:41:53 PM
Ribbon Issues
Tue, Jan 14, 2014 at 9:51:50 AM
Page generation time: 0.2303
