49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> new window family
Wed, Jul 15, 2009 at 4:55:28 PM | new window family
Bhavi
Hello everyone,
I need to make 30" X 44" casement paneled window with glass on top part. I used Glassed casement window from downloaded family and tried to make this. It looks perfect in family file but, when I load it in file, panels and glass move out of the shutter. Another problem is, when I pick the different size from this family, it changes the frame width (it should change panel size). Attached is the window which I have created. Can anybody check it and tell me what the problem is and how I can fix it? I tried to lock dimensions and alignment of object with reference plane but, it doesn’t work. Thanks.
Thu, Jul 16, 2009 at 6:12:08 AM | new window family
4 Stars: 202 Votes
You don't have the panels, trim, glass locked to the ref. planes, you must do that, use the "Align tool" to attach the elements to the ref. planes....
Thu, Jul 16, 2009 at 5:18:17 PM | new window family
Bhavi
Thanks.
 I think, I tried that but may be was not applied to all of them. I will try it again... Thanks again.
Thu, Jul 16, 2009 at 5:50:18 PM | new window family
Bhavi
Hi Typhoon,
I tried to do as per your suggestion but it didn’t work. If you have time, can you please try that and post the file so that I can learn what the difference is and where I am wrong. If you can, I will really appreciate it. Thanks.
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:31 AM
Imported family not flexing in window family
Thu, Jan 31, 2013 at 7:21:54 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:37 PM
having trouble with window rfa
Mon, Sep 8, 2008 at 10:37:12 AM
basic window family tutorial(step by step)
Mon, Sep 6, 2010 at 7:26:54 PM
Page generation time: 0.8678
