71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 7.15.09: Easy Cheesey, Grids and Peasies (editing model patterns)
Wed, Jul 15, 2009 at 9:36:04 AM | Revit TotD – 7.15.09: Easy Cheesey, Grids and Peasies (editing model patterns)
rkitect
rkitect Avatar
4 Stars: 29 Votes
Well, it’s not just grids but any model pattern for that matter. This tip derives from a quick question about working on ceiling grids and the ability to move and rotate the grid pattern. However, what it turns into is a discussion on model patterns and how to manipulate them on all surfaces, not just ceilings. This is a quick and easy tip, just like the Navigating Curtain Walls tip so don’t blink, it’ll be over before you know it!
Patterns
There are a few things about patterns I want to explain real quick since you can only modify one of the two types of patterns.  In Revit you have two pattern types, model and drafting.
Drafting patterns are similar to annotation objects in Revit as they have no model scale value.  Notice in these images that the drafting pattern appears to change in size when the view scale is changed.
Think of these as symbolic fill patterns for things such as section material representation rather than representing actual objects like the size of a ceiling grid.
Model patterns on the other hand maintain a model scale that is independent of the view scale.  Notice that when I change this pattern, the spacing of the lines representing the bricks maintain their original spacing.  Model patterns should be used when you need to represent actual sizes for repetitive objects (ie: ceiling tiles, floor tiles, wood siding, etc.) without actually modeling them.
The difference can be made more apparent by looking in the .pat file (vailable at: C:\Program Files\Autodesk Revit Architecture 2010\Data\).  By the way, I highly recommend you open the .pat file located in there and read the description of the differences between model and drafting patterns.
With that said, note that you can only do the following when Model patterns are in use on the surface you are manipulating.
Playing with your Grids
  1. This can be done in any view that you can see the pattern, excepting a camera view.
  2. Hovering over the surface with your pattern, Tab through the selections until a single line of your pattern becomes available.
  3. Use any of the following modify tools to achieve the configuration you desire with your pattern:
    1. Move
    2. Rotate
    3. Copy (as in to the clipboard)
  4. Simple as that!..
Hope this has helped some of you looking how to do this.  This will lead into another TotD later down the road on aligning your surface patterns with your render appearance materials.  Another super easy task that can greatly improve the quality of your renderings!  Until then, thanks for stopping by for another Revit TotD!
Remember that you can view this tip in its entirety at: http://revittotd.com/07/480  with pictures and video clip!
-Carl
Edited on: Wed, Jul 15, 2009 at 9:38:22 AM
Editing Model Patterns...
Mon, Jan 4, 2010 at 12:56:50 PM
Where do model patterns go?
Thu, Sep 24, 2015 at 9:37:41 PM
Revit TotD - 2.17.10 | Linked Model Visibility, part2
Wed, Feb 17, 2010 at 9:22:44 AM
Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:46 AM
Revit TotD - Linked Model Visibility, part 1
Mon, Feb 15, 2010 at 9:08:56 AM
Page generation time: 1.9117
