61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Perspective View Issues!
Tue, Jul 14, 2009 at 2:54:03 PM | Perspective View Issues!
bakerb1
Hey Everyone,
 This has happened to me before on 08, 09, and now 10, but it has never been quite this bad before.  I have build my entire model, and am now setting up perspective cameras to get some render shots and for some reason everything goes crazy!  Surface patterns are here and there, some walls seem nearly invisible, interior walls appear to cut right through the exterior walls, sweeps dissappear, etc, the list goes on and on!  I have attached a shot so you can see what i'm talking about.
 It's important to note that in plan, elevation, and the {3D} view, everything is perfectly fine.  Also, when actually rendered, everything turns out fine.
Anyone know what is happening here?
Tue, Jul 14, 2009 at 2:56:38 PM | Perspective View Issues!
bakerb1
sorry, the file must have been to big
Tue, Jul 14, 2009 at 3:04:42 PM | Perspective View Issues!
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
See this thread for a starting point.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=17019
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Jul 14, 2009 at 3:05:27 PM | Perspective View Issues!
This is a memory issue.  You might describe your system.
Tue, Jul 14, 2009 at 8:05:41 PM | Perspective View Issues!
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Hi -- I've seen very similar issues arise with my 3D views.  For reasons unknown to me, the "Eye Elevation" sets itself to tens or hundreds of thousands of feet away from the model.  Check to make sure this isn't the case--that you aren't looking at your building from outer space.
Moving Objects in 3d Perspective View
Wed, Jul 27, 2016 at 3:52:15 PM
perspective view
Thu, Feb 7, 2013 at 1:47:35 PM
Wishlist - Default perspective 3d view
Fri, May 2, 2014 at 9:31:10 AM
Working in Perspective View
Thu, Jul 19, 2018 at 2:19:59 PM
13
Perspective Problem
Fri, Jun 26, 2009 at 12:13:44 PM
Page generation time: 1.5152
