100 Users Online (99 Members):
Forums >> Revit Building >> Technical Support >> NEED HELP with Revit MEP - pipes obscured by connector "halo" on plan views
8 Posts No Rating |
I'm currently working on a project in Revit MEP, it's actually the first time I did a full project all in Revit. Now I have to present the drawings for permit purposes, so I wanted the pipes to come out NOT in a single - line diagram format but as the actual pipes look. But when I printed the plans, I saw that there seemed to be a "halo" around the fixtures, which obscured the pipes' geometry in the view. Now if these drawings were to be used by a contractor it wouldn't be possible to see the details anymore because of the "halo". Is there something I'm missing? There seems to be nothing wrong in 3D view, but we also need the plans to be readable. Hope sombody can help me on this.
8 Posts No Rating |
By the way, I'm using Revit MEP 2009. Thanks.
can't "reach" pipes (revit MEP) |
Wed, Dec 21, 2011 at 6:24:35 PM
Duct Connector Not Visible?? |
Thu, Feb 17, 2011 at 11:41:00 AM
RevitMEP 2010 - Fixing Errors - "Check Duct Systems" + "Check Pipe Systems" |
Fri, Sep 18, 2009 at 11:59:29 AM
Ceiling Plan tags in Linked Model Views "Moving" (2010) |
Tue, Dec 21, 2010 at 7:20:58 AM
Visibility in Plan/Section Views |
Tue, May 19, 2009 at 3:54:16 PM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
