Forums >> General Discussion >> Revit Project Management >> How would I draw these shapes?
Hey guys, I am going through the family tutorials looking at drawing different shapes (extrusion, blend, sweep etc) and can not figure out how I would draw the shapes on a model I have made (I assume this would be done as a conceptial mass aswell?) Here is a photo (its more the triangular parts at the front, i can do the boxy main part with a blend), help would be great.... [url=http://img188.imageshack.us/i/p1010217q.jpg/][img=http://img188.imageshack.us/img188/8140/p1010217q.jpg][/url]
I can't "open" the images to see what do you want, attach the file here in "File Attachments"....
This is the image.....
I think I would do that in 2010 with a mass that has joined forms and voids. I saw that someone on AUGI suggested roofs but that would still be hard.
I remember that I gave some ideas in this thread....http://www.revitcity.com/forums.php?action=viewthread&thread_id=16858
I think i use the new "Conceptual Mass" to do that...
thanks guys, i followed your idea of a blend conceptial mass for the main building you suggested before erland73, but I just done really know how to do the triangle side walls, even if it were a conceptial mass would i use a blend, extrude or sweep etc? It would be great if someone could give me some screenshots of a process if possible.thanks so much
"even if it were a conceptial mass would i use a blend, extrude or sweep etc?" - If you use the "Conceptual mass" you don't have the Sweep, blend or extrude, that is in"Create-in-Place", can you put several images (different angles) to see the model?? I can't see well the model only in that image... but i use the Conceptual Mass to do that...
Edited on: Wed, Jul 15, 2009 at 7:51:15 AM
here typhoon, cheers mate!! some more images http://img190.imageshack.us/i/p1010129c.jpg/ http://img32.imageshack.us/i/p1010139i.jpg/ http://img36.imageshack.us/i/p1010236h.jpg/ copy the links to see
Use the new "Conceptual mass" to do that, you have the option to grab the points and move them where you want...
how would i then void it in the middle?
In the middle??? you don't create anything in the middle, did you see my image??
