72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Yes / No Void
Mon, Aug 1, 2005 at 11:53:54 PM | Yes / No Void
fcsl
I have created a VOID to a component but I want to allow flexibility of having it or not using a parametric radius. However, the radius cannot be zero to get rid of the VOID. Is it possible to use Yes/No Parameter to control its occurence? Or other ways can do and how? Regards,
Tue, Aug 2, 2005 at 1:33:54 AM | RE: Yes / No Void
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not possible to turn the curve off, however you could set it up so you have a yes/no parameter for a curve then based on which selected you could create parameters that adjust the void so it doesn't cut the and straight line void cuts and vice versa...
Tue, Aug 2, 2005 at 3:45:51 AM | RE: Yes / No Void
fcsl
Thanks Mr Spot.
Mon, Aug 17, 2009 at 11:45:05 AM | Yes / No Void
jhayden
jhayden Avatar
I'm trying to create a seat for a precast double tee family by creating an void extsion running along each end of the tee. I set up some 'yes/no' parameters but I can't apply those parameters to the void extrusion. I made the family in the 'beams and braces' family template as well as the 'generic model line based' family template hoping the problem was the template, but it wasn't.
Could someone tell me how to apply the yes/no parameter to a void extrusion?
Thanks
Mon, Aug 17, 2009 at 11:51:30 AM | Yes / No Void
Can't but read my post in this thread for how yoiu can do this. http://www.revitcity.com/forums.php?action=viewthread&thread_id=17452
Mon, Aug 17, 2009 at 11:52:06 AM | Yes / No Void
Bronsart
You can't use a yes/no visiblity parameter with a void.  You might need to find a work-around so you do not need to use the void.
Mon, Aug 17, 2009 at 6:09:37 PM | Yes / No Void
dashgarnett
I learned this in AU ad David B's class on fuzzy math for families. He did not use the parameter to turn off the void but to move it out of the way it is intersecting. used it to create window in doors as a yes no.... so the yes/no parameter just added X' to the location of the depth of it so it effectively pushed it away from the mass it is cutting.
Void Masses
Fri, Oct 3, 2008 at 4:11:07 PM
void in family is yellow
Mon, Mar 12, 2018 at 12:22:44 PM
Void Sweeps
Thu, Nov 24, 2005 at 10:31:46 PM
Moving Void Forms
Thu, Feb 3, 2005 at 5:39:38 PM
Selecting Invisible Void Sweeps
Wed, Jan 28, 2009 at 4:23:10 PM
Page generation time: 1.1055
