41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> flexing model doesn't work in 2008
Mon, Jul 13, 2009 at 10:44:14 AM | flexing model doesn't work in 2008
adeuley
I built a family that you align to the ceiling and the floor. and then the height of certain parts change based on the height of the ceiling. When you insert and align it to the ceiling and then to the floor everything adjusts that way it should but if you change the ceiling height it throws a constaint error so i hit remove and then go back and realign the bottom to the floor and everything streches like it should. Any ideas why the one dimension won't flex. It is set as an instance parameter. Thanks
Void extrusion on "model in place" doesn't work.
Sun, Aug 2, 2015 at 2:10:21 AM
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
grant permit request doesn't pop up
Tue, Aug 1, 2006 at 1:27:31 PM
Exporting a rvt file to Sketchup; Saving a 2009 file to 2008
Sat, Oct 3, 2009 at 12:53:39 PM
Model groups and phasing - Demo doesn't update?
Wed, May 23, 2012 at 5:41:55 PM
Page generation time: 1.6268
