45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> FILL PATTERNS ON A CEILING PLAN
Fri, Jul 10, 2009 at 8:47:28 AM | FILL PATTERNS ON A CEILING PLAN
Bimman
Bimman Avatar
1 Stars: 2 Votes
I need to show a gyp clg hatch but when i set it to show, it makes all my elevations with gyp show the hatch as well.  how would i go about showing the hatch on the ceiling plans so it does not change my other views
PWD
Fri, Jul 10, 2009 at 9:02:53 AM | FILL PATTERNS ON A CEILING PLAN
Is this just for one view and not a model element?  If so, the make it be a fill.  If it is a model element then create a new for this one ceiling and give it its own material with this pattern.
Fri, Jul 10, 2009 at 9:08:06 AM | FILL PATTERNS ON A CEILING PLAN
Bimman
Bimman Avatar
1 Stars: 2 Votes
IT IS JUST FOR THE VEIW.  i WAS TOYING AROUND WITH BOTH OF THOSE IDEAS BUT WAS NOT SURE WHICH WOULD HAVE BEEN THE CORRECT WAY TO GO ABOUT IT
 SINCE IS JUST THE VEIW IS THERE A FLOOD TYPE FOR THE FILL OR DO I NEED TO SELECT THE FILL SHAPE.
 THANKS
PWD
Fri, Jul 10, 2009 at 4:18:13 PM | FILL PATTERNS ON A CEILING PLAN
jarosa
jarosa Avatar
4 Stars: 5 Votes
It sounds like the material you selected for the ceiling is the same as the wall material and when you changed the fill pattern for the gyp board it shows in both the wall and ceiling. Do what WHubb suggests. Make a new material and apply it to the ceiling in the properties and change your wall material fill pattern to blank. This should get you a gyp board pattern on your ceilings and no pattern on the walls.
John
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns disappear in Roof Plan
Thu, Jan 7, 2010 at 2:08:39 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:09 AM
Model Fill Patterns
Tue, Jun 22, 2010 at 11:35:19 PM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Page generation time: 4.4554
