Forums >> Revit Systems >> Technical Support >> Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
6 Posts No Rating |
I get an Warning when trying to import a 3D AutoCAD file into Revit as follows - "Warning: Some ACIS Objects could not be imported. To import them, use AutoCAD to convert them to Polymesh Objects and then reimport." Question - What command do I use in AutoCAD to convert the ACIS Objects (3D Solid) to Polymesh Objects so they will import and display in a Revit Model?
Try this LISP routine.
![JPrior Avatar](user_avatar/119291.jpg)
![4 Stars: 1 Votes](/images/stars_4.gif) |
I'm getting the same error as SD Binc. I loaded this lisp but it is Poly mesh to 3D Solid only. Do you have one that will changes a 3D solid to Poly Mesh? Thanks
warning attached
Edited on: Thu, Jan 27, 2011 at 9:59:24 AM
Check here: http://www.accustudio.com/index.php?option=com_content&view=article&id=48:freeware&catid=34:marketplace&Itemid=58
9 Posts No Rating |
Anyone came up with solution for this ?
having the same problem and dont quite feel like redrawing the whole model in revit ![Smile](/images/smiles/smile.gif)
there must be a way, right ?
1 Posts No Rating |
We only draw in ACIS Objects. I've never 'converted' the objects to polyface mesh to import to Revit MEP. Usually, I select all and do one round of Explode, save as a new file, then link/import that into Revit.
You can also import that .dwg into a Revit family, insert the family into your project, then you can do interference checking as well. We do this quite often with 3d-dwg's from other consultants who export from more specialized programs (Civil, Structural, Fire Protection, etc.) to coordinate our piping, plumbing and hvac.
Hi Everyone,
Just joined RevitCity, first responce to a question.
If you are using AutoCAD 2006-2009, do the following to change solid to mesh:
1) Explode solid.
2) Type 3DSOUT and pick location.
3) Type 3DSIN and re-import solid, that's it.
If you are using AutoCAD 2011-2012, do the following to change solid to mesh:
1) Explode 3D solid which converts it to Regions.
2) Type CONVTOMESH, select Region objects, and that's it.
If none of the above works, send me your file and I will see what I can do.
Hope that helps,
1 Posts No Rating |
did someone already got answers on this....?
@NAMECIB7610, will it be ok if i send you my file to convert it into a workable revit file.
1 Posts No Rating |
I've got the same problem. In this dwg-file, there are 2 3d Solids. When I import them into Revit 2012, I get just faces.
I want to have a 3D geometry so I can add patterns when I cut this object.
Is this possible, without redrawing it?
7 Posts No Rating |
I was able to overcome this issue by converting the .sat file to a .dxf file using AutoCAD and then importing the dxf file into REvit.
See my post on this thread for details... http://www.revitcity.com/forums.php?action=viewthread&thread_id=21421
Edited on: Fri, Oct 12, 2012 at 7:33:16 AM
CAD exporting RE:What is an ACIS solid |
Fri, Jan 4, 2008 at 4:22:43 PM
ACIS Import |
Thu, Jan 26, 2006 at 11:53:32 AM
Create 3D person family |
Fri, Mar 13, 2015 at 8:34:29 AM
CONVERT RHINO TO REVIT |
Thu, Feb 13, 2020 at 5:10:11 AM
fabmep to revit |
Fri, May 8, 2015 at 9:51:35 AM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
