87 Users Online (85 Members):
Forums >> Revit Building >> Technical Support >> rounded roof fascia and gutter?
![mmetin Avatar](user_avatar/7837.jpg)
46 Posts No Rating |
can you give me an idea to create rounded roof fascia and gutter?
90 Posts No Rating |
You can put new refernce plane for sweep in roof plane from elevation ...
You should be able to get it to work using an in-place family and selecting the roof as the work plane and then picking the edge for the sketched path. Then simply select the profile.
NOTE: You cannot have a profile with non straight lines and a path that contains splines or ellipses, so it would need to be a simple curve.
Need Help With Soffit, Fascia, Gutter |
Fri, Dec 5, 2014 at 11:09:19 AM
Cut Fascia by roof |
Mon, Jun 25, 2012 at 10:39:49 AM
Gutter to extend when using join/unjoin roof |
Thu, Jul 2, 2009 at 8:40:03 PM
Fascia Gutter Miter |
Wed, Mar 4, 2009 at 3:11:14 PM
RAC09 - Roof Fascia Corner Miter on Square Cut |
Wed, May 27, 2009 at 6:57:00 PM
Members: | 2022428 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
