118 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> render problem
Thu, Jul 9, 2009 at 5:03:33 AM | render problem
grant7
Hi All,
with any other material in my project when I change the render image it works fine. But if I change the image on my house double brick wall material it still always keeps rendering as this grey blah colour?
Any clues pse - rev Arch 2009
Thanks
Grant
Thu, Jul 9, 2009 at 7:12:55 AM | render problem
You still have not defined the matertials for your wall.  You can assign that material in the properties of the wall.  Edit the structure and assign the materials to the exterior layer.
Thu, Jul 9, 2009 at 4:49:23 PM | render problem
tim123
4 Stars: 19 Votes
If you're using phases this could be causing it to render incorrectly.  If this is the case, check the phase settings.
Render problem
Thu, May 30, 2013 at 12:37:30 AM
Render in Cloud Problem
Fri, May 24, 2013 at 8:19:24 AM
Render problem in 2009 with existing phase
Thu, Aug 28, 2008 at 2:55:46 PM
New Render Appearance
Tue, Jul 6, 2010 at 9:45:23 AM
Wooden floor render problem - how to change direction of flooring???????
Fri, Mar 18, 2011 at 2:42:50 PM
Page generation time: 2.4590
