Forums >> Revit Systems >> Technical Support >> HELP! How do I change pipe drop and rise symbol sizes?
3 Posts No Rating |
I see in the MEP settings tab it shows you what symbols are used I can not find where to eedit these, I opened the pipe profile file, cant see anything in there, any help appreciated.
3 Posts No Rating |
Found it, but does anyone know how to change symbols for pipes rising and dropping, I would like to add a half circle, instead of the ¾
While in the project, click on an elbow. Edit family. While in the family editor, go to the plan view. You will notice some "model lines" depicting the 3/4 circle. You can adjust that to be a half circle like you said. Alternatively, you can use "symbolic lines" so that the half circle will not show up in sections or 3D. Symbolic lines only show up on the view that you drew them in. Now when you are satisfied, save family as .... and load family into project. Back in the project view, click again on the elbow you initially clicked on. Change it to the elbow you loaded into the project. HTH Joe
rise and drop dimension |
Fri, Jun 19, 2009 at 2:30:17 PM
Pipe Sizes |
Thu, Jan 22, 2009 at 5:56:12 PM
Calculating Pipe Sizes |
Thu, Jan 13, 2011 at 4:30:41 PM
Revit MEP Custom User Pipe Sizes Not Available When Drawing Pipes |
Sun, Dec 18, 2016 at 8:51:18 PM
How to control Pipe rise/drop annotation size to mininum value? |
Thu, Sep 22, 2011 at 4:23:01 AM
Members: | 2115099 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
