40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Skylights and Ceilings
Wed, Jul 8, 2009 at 9:52:12 PM | Skylights and Ceilings
eltazar
Ive been working on a job that has several skylights and ive created my basic family for the skylight that cuts through the roof which works very well. To speed up the process of positioning each skylight and cut the ceiling openings i was wondering if it is possible To project the opening onto the ceiling. By the way the Roof is pitched at 22.5 degrees and the ceiling is flat?
thanks for your help.
Thu, Jul 9, 2009 at 3:56:08 AM | Skylights and Ceilings
sagarkagathara
sagarkagathara Avatar
Create a ceiling-based family with a void (to cut the ceiling); make this family 'shared' and load it into Skylight family, place accordingly.
Now, when you load  Skylight into project, the ceiling-based void will also load and cut the ceiling when you place skylight.
I haven't tried this myself, but I believe it should work.
Thu, Jul 9, 2009 at 5:01:31 PM | Skylights and Ceilings
eltazar
thanks for that. It sounds like it should work ill have to try it. Thanks again.
window schedule - skylights
Wed, Jun 7, 2006 at 10:00:03 AM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:08 AM
Complex ceilings
Thu, Oct 8, 2015 at 1:02:55 PM
cant get color out of the view
Thu, May 1, 2014 at 2:12:48 PM
Wall/Roof Attachment Phasing Issue
Wed, Aug 27, 2008 at 2:34:17 PM
Page generation time: 0.9922
