48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> RFA turns black
Wed, Jul 8, 2009 at 2:13:16 AM | RFA turns black
Palazzo
I have a problem when rendering a file with al lot of rfa's (mostly cars)
The cars with metallic colors render black (flat, not metallic), but the reflections render in original colour.
Sometimes changing the view helps, but not for long.
Can someone explain why this happens (or is it a Revit-bug?)
Thanx!
Wed, Jul 8, 2009 at 3:46:59 AM | RFA turns black
Palazzo
Almost forgotten; we are using Revit 2010
Wed, Jul 8, 2009 at 4:53:23 AM | RFA turns black
tim123
4 Stars: 19 Votes
Can you upload an image showing your problem?  If your materials are set up correctly it's probably a driver problem rather than a Revit problem.
Wed, Jul 8, 2009 at 8:22:11 AM | RFA turns black
Palazzo
Tim,
I'll have to render one, i don't save the bad renders. I will make a new one.
I don't think it's a driver problem, The computers over here have various GPU's and drivers, neither of them works.
We did find it has something to do with metallic colours, because other (none-RFA) elements do have the same problem, but still we do not have the solution...
Wed, Jul 8, 2009 at 8:27:08 AM | RFA turns black
I think your problem is a memory issue.  You really have to watch using some of the cars posted here because they just have too many facets.  Closing Revit to release all memory then restarting and only opening the window you want to render from will help but may not fix the problem.  You don't need a super detailed car for distant elements.
Mon, Jul 13, 2009 at 8:55:35 AM | RFA turns black
Palazzo
Ok, the solution,
Revit has only a problem with the RFA's when the background (with rendering) is set to 'color'
Changing it to sky solves the problem!
Revit 2008 - changing pattern overscaling color from gray lines to black
Tue, Nov 20, 2007 at 6:25:41 AM
Cloud Rendering Very Black
Tue, Mar 25, 2014 at 11:19:06 AM
New Construction Wall showing up Black on exterior
Tue, Jan 24, 2012 at 3:50:51 PM
Black background in text box
Fri, Feb 19, 2016 at 7:23:03 AM
Material's render a different color
Thu, Oct 20, 2011 at 9:13:21 AM
Page generation time: 0.7748
