Forums >> Revit Building >> Technical Support >> KEYNOTES
i am trying to keynote my plans??? if i have a key note i need to call 1 and say it is a folding partitin door. i have set my keynote in the door family to 1. when i go to make the keynote schedule it does not give the text for the door it just states 1 and the text is blank. not sure how to link the two together. i am not sure if i am making any sense but any help on how to make a keynote schedule would be great. also i have watched a few youtube clips and they did not help a lot.
----------------------------------- PWD |
IK suggest you start by reading all the items in your HELP for keynoting.
it looks like i need to create a custom database is that correct?
Database ... I guess you can call it that - It's just a simple txt file .... you can do it with word ... notepad or excell but it has to be in the correct format. Keynote number Keynote text (all in one line)
Edited on: Tue, Jul 7, 2009 at 10:00:01 AM
i got it to work. but i had to make a copy of revits defult and place my notes inside the default file name. if i have my own file where do i set revit to look for my txt file with the new name.
found it thanks for all your help, i was really confused. but it was not as difficult as i thought it was going to be
NOW THAT I HAVE IT FIGURED OUT, I HAVE ANOTHER QUESTION. WHEN SORTING BY KEYNOTE OR BY SHEET IT SEEMS TO CHANGE IT IN ALL INSTANCES. IS THERE A WAY TO HAVE EACH LEGEND ONLY SORT ONE WAY OR THE OTHER OR WILL IT ALWAYS SORT ALL LEGENDS TOGETHER. ALSO CAN REVIT PULL INFO FROM MULTIPLE TXT FILES FOR DIFFERENT KEYNOTE NUMBERING.
"IS THERE A WAY TO HAVE EACH LEGEND ONLY SORT ONE WAY OR THE OTHER" - Set up different legends. "CAN REVIT PULL INFO FROM MULTIPLE TXT FILES FOR DIFFERENT KEYNOTE NUMBERING " No - But you can use A1, A2, A3 and C1, C2, C3 ... etc then filter in your legends. Numbering method "by sheet" - "by keynote" is a project setting ... One or the other.
Edited on: Wed, Jul 8, 2009 at 10:52:04 AM
So by setting up seperate legends, each legend is not dependent on whether or not the other is set to sheet or keynote. I have tried that but it still seems to be changing all my legends. is that what you mmean by project setting.
Settings / keynotes ... is where you set the numbering method PERIOD! But, you can flter / sort - your keynotes in your legend (s). And you can use different keynote tags. We use one shape for general keynotes (G1...etc) and have a legend that sorts those... then a different tag for specific keynots and have a legend that sorts those.
Keynotes |
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes |
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend? |
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing |
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management |
Mon, May 11, 2009 at 7:01:29 AM
