Forums >> Revit Building >> Technical Support >> Some hatches doesn't plot
11 Posts No Rating |
HiI have a ceilingplan where some of the patters/hatches doesn't get printed.I have two identic ceilings whith the same pattern, but only one is getting printed - why? They have the same properties, patterns, height etc. I can se them both in the sheet, but only one get printet.
If they both have the same properties ... color ... linetype ... no phase differences and they are both the same scle, they should plot correctly. Try printing to a PDF. If they show up there, then you have printer issues.
I had the same problem with a wall sweep. I had a short deadline, so I didn't have time to mess with it. So, I just pulled the view (interior elevation on my end), and added a hatched region that had the pattern I wanted. I know it's a round-a-bout way to get it done, but it worked.
Cheryl Nelson Randall W. Hein Architects |
Ceiling grid won't plot |
Thu, Apr 1, 2010 at 10:40:05 AM
Detail Levels |
Thu, Sep 22, 2005 at 1:09:37 PM
Linked AutoCad text emergency |
Mon, Mar 10, 2008 at 12:56:06 PM
ERROR WHILE PREVIEWING A PLOT. REV 9 |
Mon, Aug 4, 2008 at 12:57:34 PM
Plot Preview in PDF |
Wed, Feb 22, 2012 at 11:28:24 AM
Members: | 2104569 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
