Forums >> Revit Building >> Technical Support >> "Solid white" filled region that prints in black
Hi:
The problem is that i have a "Solid white" filled region that appears black in the pdf i print.
Has anyone a solution?
Thanks in advance.
What are the settings you are using for the solid white filled region, you have to options:
1. No Fill, opaque background, white...
2. Soloid Fill, opaque background, white...
Also what PDF program are you using as i've never had any troubles with both settings above?
I cannot answer you right now, I'll have the settings next Monday and i'll post them A.S.A.P.
Thanks.
Also check that your haven't got set in your print settings to print black and white... Instead use greyscale if you need to remove any colour...
The settings are: 2. Solid Fill(Drafting), opaque background, white...
The PDF driver is the 'Pine Bush driver. (4.2, I think).
And I changed the 'Black lines' setting to 'Grayscale' and the problem exists no longer... so, thank you very much Mr Spot, you got the point.
WHY WILL SOLID BLACK "ANNOTATION FILLED REGION" NOT PRINT! |
Sun, Aug 3, 2008 at 1:51:23 PM
filled region pattern color changes when drawing scale changes |
Thu, Apr 14, 2016 at 7:32:07 AM
Help needed to Align a Filled Region to a "family" (Deck Span Direction) |
Mon, Jan 14, 2008 at 12:38:57 PM
Detail Component / Filled Region |
Wed, Aug 19, 2009 at 10:57:45 AM
Filled Region in Family? |
Tue, May 26, 2009 at 7:36:47 AM
Members: | 2101366 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
