Forums >> General Discussion >> Revit Project Management >> Upgrading Files to new Revit 2010
Is there a plug-in, add-on or something out there that can be used to upgrades all the previous revit versions to the new version of revit at once or at least several at a time?
There is a script somewhere.... possibly on the installation DVD? I have used it on previous releases but I forget where you get it.
24 Posts No Rating |
Have you found this and tested it yet? If so can you let us know cause I would really like to change all the families .... as we currently have not received a family converter for 2010
No - I have not found it yet.
http://revit.autodesk.com/pillar/custserv/web/service/support_4.0/faq/Installation/2_installation.asp
Brett - That link says 2002 at the bottom. What versions does that convert?
Oops, guess that needs to be updated, my bad. I haven't checked to see if that would update the newest or not. Thanks for checking that. I would just use the batch that's on the install CD
Here is the batch upgrade from the 2010 disc.
