50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Custom Material
Mon, Jun 29, 2009 at 9:00:02 AM | Custom Material
vrmoreno3
In previous version, I was able to create a custom material with a tile pattern, example for standing seam metal roofing. In the newest version I can't find out anyhow to create these patterns. It is the new rendering and material with Revit 2010 and 2009.
Mon, Jun 29, 2009 at 9:03:13 AM | Custom Material
4 Stars: 203 Votes
I don't know what's the problem, it's the same.....
Mon, Jun 29, 2009 at 9:04:49 AM | Custom Material
tim123
4 Stars: 19 Votes
Go to the Render appearance dialogue box of a material and click on replace.  You can then take one of the existing options and change the settings or maps to what you require, or use the generic material and add maps or bump maps to it to give the material that you want.
Mon, Jun 29, 2009 at 9:15:22 AM | Custom Material
4 Stars: 203 Votes
Are you still work with revit 9 or 2008?? that's why the question Vrmoreno3????
Mon, Jun 29, 2009 at 9:28:37 AM | Custom Material
vrmoreno3
I use 2010 now. In the previous versions there used to be a specific area for tiling. i haven't found one in this version yet. Also, how do you create a new material based on a existing material. This also was available in previous versions. When I say previous, it was before they changed rendering engines.
Mon, Jun 29, 2009 at 9:30:27 AM | Custom Material
4 Stars: 203 Votes
In left/bottom you have a buttom to "Duplicate" a material, then do like Tim123 told you....
Mon, Jun 29, 2009 at 9:51:44 AM | Custom Material
vrmoreno3
I have reviewed each of your response and thanks. Now, I do not want to change an existing library item. For instance "Copper Patina Hammered" I want to use and duplicate and make a new item "Copper Patina Standing Seam" without changing the original. How is that accomplished. It seems like everytime I think I have Revit figured out, they change it somewhat.
Mon, Jun 29, 2009 at 9:59:58 AM | Custom Material
tim123
4 Stars: 19 Votes
You will not change the library items - it will only be in your project.  Just duplicate as Typhhoon says, adjust as required and you're done.
Mon, Jun 29, 2009 at 10:26:27 AM | Custom Material
vrmoreno3
Ah, so the material changes are project based, not global? Thanks a bunch.
Mon, Jun 29, 2009 at 10:47:47 AM | Custom Material
Actually, materials can be set in the family and are in this respect global ... except once a material is set in the project, then the project controls.
Material Library with custom parameters.
Fri, May 6, 2016 at 3:36:29 PM
adding arrow head to custom tags
Sat, Aug 3, 2013 at 9:49:15 PM
Revit 2011 Custom Material Crash (Video)
Tue, Jun 7, 2011 at 1:23:21 PM
Question about shared custom material library
Wed, May 18, 2016 at 6:44:31 AM
Custom Material Rendering black
Thu, May 31, 2012 at 5:04:30 PM
Page generation time: 2.3923
