79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Beam control points
Mon, Jun 29, 2009 at 7:05:23 AM | Beam control points
line
Hi         Does anyone know how to change the control points to be below the structure instead of above?
There does not seem be anything about this. I know I can rotate the beam profile by 180 and i will get the same result. Would be good if the beam is modelled correct in family instead of rotation when the beam is in the central file.
I have attached an image to illustrale which point i am refering to.
Thanks
Mon, Jun 29, 2009 at 8:58:40 AM | Beam control points
tim123
4 Stars: 19 Votes
Can you elaborate on what you are trying to achieve?  I can't think of why it would make a difference.  By default the beams are placed with their levels at the top and this is the normal convention with beams that I've seen in the past.
Mon, Jun 29, 2009 at 9:45:54 AM | Beam control points
line
Hi Tim Yes, It is a longer story. I am setting up a drainage system(with a circular profile and one with a box gutter profile).I have several drains running into one main drainage pipe.                                                             I looked into the sweep blend tool (and found some tutorials here on revit city, which was were very comprehensive).I found that the sweep blend tool was harder to control with the level start and begin. I am considering if we should go back to this option again though. However I can’t get the geometry to cut each other probably in the open drain sections (maybe I have not tried hard enough on this one yet see attached image).                                          I also looked into using the rail family but it doesn’t want to join.                                       The initial idea was to have a beam family where there already was a constant fall (which ideally would be parametric). This does not seem posible which is why I am out in a small D-tour. So the only thing you had to was to draw a line and adjust the heights.I find the beam system working nicely because you can easily set it up for others to use and by using the structural concrete material the joining is really good. It is also fast to change the fall either by typing distance or using the align tool to the reference plane. In the mass you had to go inside the mass and then into the profile to change the fall. Regarding the previous post; As the drain is in an internal part of the building there has been a request for setting it out from the bottom of the pipe instead of top.
 Thanks for your patience
Mon, Jun 29, 2009 at 10:15:25 AM | Beam control points
tim123
4 Stars: 19 Votes
If you're using reference planes to align the beams to then you can use them for the setting out also.  The elevation marker tool will also snap to the bottom or top of a beam.
adding control points on a mass model
Fri, Oct 15, 2010 at 11:08:17 PM
Non-Planar/Sloped Beam Systems with Elevation Points?
Thu, Jun 14, 2007 at 12:11:36 AM
the incredible shrinking beam
Thu, May 5, 2011 at 6:40:16 PM
Beam systems question
Tue, Sep 30, 2008 at 2:23:42 PM
Sloped Beam Systems in Revit Structure 2009 question
Thu, Sep 25, 2008 at 11:28:57 AM
Page generation time: 1.3380
