76 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Moving an entire building
Mon, Jun 29, 2009 at 6:36:03 AM | Moving an entire building
Narcosis
Anyone know how to select a whole structure including all internal partitions on all levels in order to move it from one place to another?
Mon, Jun 29, 2009 at 6:57:32 AM | Moving an entire building
tim123
4 Stars: 19 Votes
Use the relocate project function under position in the manage menu in 2010.
Mon, Jun 29, 2009 at 7:04:32 AM | Moving an entire building
Narcosis
Sorry, forgot to mention, using 2009.  Just want to move the building 3m to the right. When I select the building in SITE view, it should select all. However, when I try to move it, there are several constraints errors and joined elements.  If I remove constraints and unjoin to move then some of the walls/partitions and lift core don't move properly and some get deleted.
Quite frustrating
Mon, Jun 29, 2009 at 7:35:36 AM | Moving an entire building
tim123
4 Stars: 19 Votes
You can do the same thing in 2009 - it's under site I think.  Moving the whole building using the move command is not advisable due to some of the things that you have just mentioned.  If you have to, move the site rather.
Mon, Jun 29, 2009 at 8:13:48 AM | Moving an entire building
You may also want to read the artical on Revit's coordinate system in this AUGI publication: AUGI|AEC EDGE
Mon, Jun 29, 2009 at 10:57:52 AM | Moving an entire building
Narcosis
Thanks guys, sorry, I've been in a meeting all afternoon.  I'll give it a try this evening.
Moving an entire plan
Mon, Oct 29, 2012 at 7:31:52 AM
Changing level height values while keeping building in place? [ 1 2 ]
Mon, Apr 13, 2015 at 1:47:49 AM
18
moving half a building
Wed, Mar 29, 2006 at 5:23:21 PM
Moving entire building down...
Thu, Jun 23, 2011 at 4:10:35 PM
Moving Toposurface. Imported from AutoCAD file.
Tue, May 12, 2015 at 7:24:20 AM
Page generation time: 0.8735
