155 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> New wall types
Thu, Feb 26, 2004 at 3:11:40 AM | New wall types
Beauceron
Why are there no wall templates? I`m trying to bulid a modulewall where the user can after drawing the wall alter the size of vertical panels that the wall consists of. Any advice on this will be grately apreciated!
Thu, Feb 26, 2004 at 6:07:16 PM | RE: New wall types
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
If I understand your question correctly, this can be done by editing the section properties of your wall, under the structure edit command.
Hiroshi Jacobs
The Catholic University of America
Fri, Feb 27, 2004 at 6:18:44 AM | RE: New wall types
Steve_Stafford
5 Stars: 2 Votes
Are you referring to panelized "tilt-up" wall systems that attach to a steel skelton as opposed to stick built or conventional masonry construction? Panelized systems might be better modeled with a family that you place like other components. Or you could just draw a basic wall and use a combination of surface pattens and hosted reveals to describe the joints and features of the system.
Fri, Feb 27, 2004 at 9:28:51 AM | RE: New wall types
FreeRangeMonkey
I think some people use the curtain wall tool for this. Make a panel that is your concrete wall module and a mullion that represents your joints...
Sat, Feb 28, 2004 at 4:37:01 PM | RE: New wall types
Beauceron
The type of wall i`m thinking of is typical interior office walls. You know the ones put up and pull down before you have time to get used to there being a wall.
Sat, Feb 28, 2004 at 6:59:30 PM | RE: New wall types
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
might be best done as a generic model... with size parameters
Hiroshi Jacobs
Sat, Feb 28, 2004 at 8:09:46 PM | RE: New wall types
FreeRangeMonkey
I think you would be best served by making a wall type that, by default, wrapped at both ends. Just draw them in like normal walls and don't join geometry to them. Also, edit the wall joins at either end to make them not clean up and not attach to other walls.
How do I make custom wall types publicly accessible?
Sun, Apr 4, 2010 at 2:17:08 PM
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:32 AM
Copying Arch Wall Types
Tue, Aug 14, 2012 at 9:18:26 AM
Wall Types
Wed, Feb 6, 2008 at 1:39:04 PM
Lines from different wall types showing up in elevation
Tue, Sep 24, 2013 at 10:07:46 PM
Page generation time: 1.4447
