56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Perspective Problem
Thu, Jun 25, 2009 at 4:16:58 PM | Perspective Problem
jdivina
Hi,
 does anyone know why that on my perspective drawing as shown..on the attachment..where the trees are surrounding should be a sloped hill that leads to a ditch..
is not showing like it should be on the perspective
but it shows right on the 3d model
as shown there also.
both of these drawings are on the same project. and im wondering if anyone knows how to fix the perspective part just becuse i need the perspective to render,,
'thanks
JD
Thu, Jun 25, 2009 at 4:19:27 PM | Perspective Problem
jdivina
JD
Fri, Jun 26, 2009 at 6:12:02 AM | Perspective Problem
I really can't see from your post what you are talking about.  I don't see a ditch in eithe view and even if I did, I still don't know what the problem is.  Unless terrain is extreme, it never shows up much in renderings or in photos.
Fri, Jun 26, 2009 at 9:37:43 AM | Perspective Problem
jdivina
so the ditch is beside the red tower looking thing.  it has like a concrete pad at the bottom and red looking slides.  on the bottom picture.  on the top that same thing is supposed to be in the top drawing as well.
the problem is that in the top drawing there is topo on that one and i can't see the  ditch.  but on the bottom the topo isn't there.
so pretty much its not showing proper ly at all on the perspective
JD
Fri, Jun 26, 2009 at 9:54:57 AM | Perspective Problem
Turn on shading with edges in your view 10 so you can really compare the views.  I think I see the red sloping sides... make sure you have everything on the same in both views.
Fri, Jun 26, 2009 at 10:00:35 AM | Perspective Problem
jdivina
I turned on shading with edges.
the area thats supposed to be a ditch is actually a maroon topo and it goes straight through to inside the building.
everything on visibility graphics also seems to be the same.
JD
Fri, Jun 26, 2009 at 11:42:54 AM | Perspective Problem
Sorry, but you are not giving us enough information to help you.  I can say this.  If you have modeled the items correctly and all of the items are on in both views, REVIT will show them correctly.  If it is not, then the problem is somewhere in what you are doing.  It is not a Revit issue.
Fri, Jun 26, 2009 at 11:47:01 AM | Perspective Problem
tim123
4 Stars: 19 Votes
Are you perhaps using phases, where the views are set to different phases.  It is quite normal to have the existing topography in one phase and the proposed topography (different model element) in a new phase to calculate the cut and fill.
Fri, Jun 26, 2009 at 12:13:43 PM | Perspective Problem
jdivina
hey tim,
thanks thats what it actually was.
really appreciate the help
JD
vector perspective export converts to parline?
Tue, Oct 12, 2010 at 9:09:38 AM
Perspective in sheets
Mon, May 22, 2006 at 11:34:02 AM
Wishlist - Default perspective 3d view
Fri, May 2, 2014 at 9:31:09 AM
Really Odd Perspective/3D problem
Wed, Apr 29, 2015 at 7:53:09 AM
Incorrect Perpective views. Appearing out of proportion.
Sun, May 31, 2009 at 8:05:03 PM
Page generation time: 3.0980
