66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair Stringer Problem
Thu, Jun 25, 2009 at 2:12:56 PM | Stair Stringer Problem
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I am having a crazy problem where my stair string is sloping when it is suppose to be level. does anybody having any ideas what is causing this. it was fine until i moved the boundary line down 2" and i cant get it to go back to normal. any help would be amazing!
Allen
J. Allen Ball
Revit Architecture 2010 Certified Professional
Sun, Jun 28, 2009 at 1:47:34 AM | Stair Stringer Problem
tim123
4 Stars: 19 Votes
It's possible that your lines don't break at the right point - did you get this message?
Sun, Jun 28, 2009 at 7:47:52 AM | Stair Stringer Problem
jarosa
jarosa Avatar
4 Stars: 5 Votes
I don't have Revit in front of me but I believe if you edit the stair, select the boundary line, you can set the stringer to level or sloped. Then you may have to move the split to get exactly what you want.
John
Mon, Jun 29, 2009 at 9:41:36 AM | Stair Stringer Problem
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
No there where no errors or problems reported by revit. i ended up having to seperate the staircase at the first landing to make it two stair case and that ended up fixing my problem. thanks for taking a look.
also i had to create some P P Artec chicago baulsters so if anyone needs.
J. Allen Ball
Stair Stringer Offset
Wed, Jul 15, 2009 at 2:20:56 PM
Stringer in Stair by Run: Problem with offset
Tue, May 6, 2014 at 7:44:18 PM
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Stair Stringer Question
Fri, Jul 28, 2017 at 4:01:08 PM
Stair stringer offset (2015)
Mon, Sep 14, 2015 at 9:19:19 AM
Page generation time: 1.0385
