69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Central File Problem and importing problem
Thu, Jun 25, 2009 at 11:00:06 AM | Central File Problem and importing problem
jdivina
Hi,
 Was wondering if anyone knew how to do this.
I've been reading some other forums but I actually still don't get it.
so I have this central file which i want to make a totally independant file from so I can play around in it.  But for some reason everytime i detach from central file, save as a new name there always seems to be a central file after.  but the thing is i'm reading that it makes its own central file.  i understand this but now i can't move some of the objects because it says it can't obtain permission.
 problem #2:
In this same file I am trying to imprt a autocad file so I can start working on the site with the autocad as an overlay.  It doesn't seem to show up or Its there and I am not able to see it.  Does anyone know how I can fix this problem as well.
Thanks
JD
Thu, Jun 25, 2009 at 1:40:12 PM | Central File Problem and importing problem
Once U enable worksets, there will always be a central file.  When you open a central file detached, it is ppotentially a new central file but you need to save it as such.  You can always then open this new central, work in it, then do a save to central then just quit out of it if you don't want a local.
Linked files are linked.  You can noty edit a linked CAD file inside REVIT.  But you can edit it outside Revit then reload it in Revit.
element was deleted in central file
Mon, Jun 15, 2015 at 12:22:47 AM
Central Model File locations - clouds Revit Arch 2015
Wed, Dec 6, 2017 at 10:10:54 AM
importing cad problem
Fri, Mar 15, 2013 at 6:33:53 AM
Detaching file from central and working individually
Mon, Jun 4, 2012 at 12:08:50 PM
CENTRAL FILE PATH NOT FOUND HELP HELP!!!
Sun, Feb 22, 2009 at 12:35:50 PM
Page generation time: 2.2843
