62 Users Online (60 Members):
Forums >> Revit Structure >> Technical Support >> diameter
19 Posts No Rating |
Hi! Anyone who knows how to do a diameter sign? (in AutoCAD you wrote %%3)Is there a list somewere with a short commands to different symbols?
37 Posts No Rating |
It depends on your textstyle. I think the easiest is to open Word, select the same textstyle and look for the symbols you want to use. For example the diameter symbol ø in Arial is ALT+0248 (this goes for the most styles). Good luck with it Gr, Frank
Edited on: Thu, Jun 25, 2009 at 3:45:32 AM
WHile in REVIT, gotot your start menu - pick run - type in charmap - now select the font you are using and copy clip the character you want then paste it into the REVIT text field.
Outside Diameter vs. Nominal Diameter |
Tue, Jul 29, 2014 at 8:30:33 PM
Revit MEP pipe diameter difference |
Mon, Feb 13, 2012 at 10:32:46 AM
diameter symbol |
Fri, Jul 29, 2016 at 9:08:41 AM
Spiral stairs with small diameter |
Thu, May 6, 2010 at 6:53:26 AM
pipe annotation tolerance |
Thu, Jan 2, 2020 at 9:23:48 AM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
