Forums >> Revit Building >> Technical Support >> 2009-Stair Error-Mystery
I tried to model 8' height of Monolithic stair in Revit 2009, but there is a cut in the landing(Attachment 'Stairs1'), but works fine in Revit 2008 & 2010. After doing this in 2008 and open it in 2009 it opened perfectly. To make it more clear I am attaching the requirement of my stair where I have done it in 2008 but couldn't do in 2009. Strange isn't it??? Any Comments...
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
Pavan, i create a video for you yesterday with this, you told me i create this in Metric and not imperial, here it is like you want...
According to my requirement I have 8 risers at the bottom with 1' tread depth equally and 8 risers at the top with 1' tread depth equally and if you check the section in the pdf attachment the height to the top of stair is 8'. In the attached image you have sent has 9 risers at the bottom where last tread is not equal to the previous risers and you have 9 risers at the top where the last tread is unequal. Each riser height is 6". Try now.
Pavan Reddy
Revit Manager
Here it is...
Can you check my file and let me know whatz the mistake...
Pavan Reddy
Revit Manager
2009-Stair Error |
Thu, Jun 25, 2009 at 5:55:09 AM
Simple Stair Nosing error |
Thu, Mar 5, 2015 at 9:15:24 PM
Error when inserting stair |
Fri, Feb 6, 2009 at 11:56:07 AM
revit 2009 error message |
Fri, Sep 3, 2010 at 8:23:07 AM
Stair Command |
Wed, Aug 31, 2016 at 3:32:54 PM
Members: | 2114662 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
