Forums >> General Discussion >> Revit Project Management >> angled walls
Angled walls- just wondering how you do them and where you angle them from... here is an example of what i mean: http://img411.imageshack.us/i/41217992.jpg/
You don't specify what version you have, but assuming it's 2009, one way you can do that is with a mass (Solid Blend). Go to your Design Bar--> Massing--> Create Mass-->Solid Form-->Solid Blend. Once you have created your mass just pick the side(s) of it with Wall by face tool to create you walls....
im using 2010, do I have to draw our lines and pick from the lines to create my form?
So then, you can try with Conceptual Masses, load into Project and apply Wall by face....
i dont really understand, it would be great if you could give me some step by steps. Also I take it from the solid object you made, you can turn that to a wall? thanks a lot your helping heaps!!
OK, try this other way, in your project, go to Massing & Site-->In-place Mass. In your first level draw a rectangle then go to the second level and draw another rectangle but with the displacement you require. Select both rectangles and pick Create Form-->Form-->Finish Mass. Now go to Home-->Wall-->Wall by Face and pick each sides....
Edited on: Wed, Jun 24, 2009 at 11:29:29 PM
ok great, is it the same method for the triangle part? also how does the family sort of massing work, i cant work it out and thats how you create those free form kind of shapes?
"is it the same method for the triangle part?" ...Yes, here's a link for you to learn something about the new Conceptual Masses in 2010....http://designreform.net/category/tutorials/revit-tutorials/
Angled Walls in Revit |
Mon, Jan 12, 2015 at 8:48:27 AM
Making Angled or canted walls |
Tue, Jun 3, 2008 at 2:10:08 PM
Curved Angled Glass Walls |
Thu, Jan 20, 2011 at 3:01:50 PM
Revit 2011-putting openings in angled walls. |
Sat, Sep 10, 2011 at 5:45:28 AM
DRAWING ANGLED WALLS |
Wed, Feb 20, 2008 at 7:53:30 AM
Members: | 2114621 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
