Forums >> Revit Building >> Tips & Tricks >> Revit Totd - revittotd.com
So I've been away from the forums for quite some time. That's ok, I'm back now I come bearing gifts too! I prodly present to revitcity.com forums my Revit Tip of the Day blog. I will be updating this thread whenever I post a new Tip. Please enjoy, comment and share! Site: http://revittotd.com/ Today's tip: Elevation base, Project Elevation vs. Actual Elevation | http://revittotd.com/06/340 -Carl
Edited on: Wed, Jun 24, 2009 at 3:30:10 PM
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Nice site rkitect!!!!!!!.......
45 Posts No Rating |
rk NICE!!!! GREAT site!!! I have now bookmarked as a favorite. Seriously looking forward to more of your tips. PLEASE keep them coming
Revit Totd - 6.25.09: Wall Profiles and Constraints - http://revittotd.com/06/356 Today's tip deals with wall profiles and their constraints. I actually had an older tip about this that was messed up when I upgraded to the newest wordpress earlier this year If you want the text version of that older one you can find it here: http://revittotd.com/09/40 Enjoy, comment and tell your friends!
38 Posts No Rating |
I dig it....Keep the TOD's coming!
http://revittotd.com/06/373 Enjoy, Share, Comment!
Edited on: Fri, Jun 26, 2009 at 11:24:06 PM
WARNING!!!! If you are not a BIM Manager in your office, stop reading here! This is not a tip for the drafters in the office that don't feel like placing Edit Requests to get something mundane done instead of walking over to your co-worker's desk; if you hate them that much, you probably need to have a chat with your boss. Now that that is done, what are we talking about?! Everyone who has worked on a workset project has had this happen to them at some point or another. If you haven't had it happen... I pity you because your time is coming. At some point in your workset project career, someone is going to forget to reliquish their worksets before they leave for lunch, the weekend or their one month long vacation, and you're going to have to find a way to get their worksets relinquished for them. Well, here's a quick tip on how to easily get your workset project back on track, without their help, without their file, and without their machine. Remember, if you're not the BIM Manager in your office, then you need to have them do this or ask them for permission to do this before you continue. Video here: http://revittotd.com/revit/video/TotD-6.29.09-StealWorksets.swf Stealing worksets back from your lazy co-workers: - Check for the user name that has the workset checked out. This is in the Worksets Dialogue.
- Open a new instance of Revit (I do it this way so that I don't have to save my local file to central, close, then open the central file.)
- Change the user name in the options settings BEFORE you open the central file.
- Open the central file.
- Relinquish the worksets.
- Save to central and close the central file. At this point you may want to change your user name back to your default user name if you are having problems with the other user name being applied to new Revit sessions after doing this.
- Go back to your local file and synchronize it with central (save to central) to update the workset permissions.
- You should now be able to check out the worksets you need for use.
As always, thanks again for stopping by and I hope this has helped you in some way! Please share and comment. Have a great day, and see you next time for another TotD. See this Tip in its entirety at: http://revittotd.com/06/383
Edited on: Tue, Jun 30, 2009 at 8:15:40 AM
Revit TotD – 2.19.10 | Dimension Formulas |
Fri, Feb 19, 2010 at 10:29:47 AM
Revit TotD – 10.12.09: Revit’s “Center” Command |
Mon, Oct 12, 2009 at 10:56:01 AM
Revit TotD – 7.5.09: Let that Bump do the Work |
Wed, Aug 5, 2009 at 9:52:59 AM
Revit TotD – 7.29.09: Don’t Skip the SKP Mats |
Wed, Jul 29, 2009 at 9:24:56 AM
Revit TotD - 8.26.2010 | Quick Plan Perspectives (via View Cube context menu) |
Thu, May 31, 2012 at 3:02:55 PM
Members: | 2114539 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
