72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Steel Beams
Thu, Jul 28, 2005 at 6:04:35 AM | Steel Beams
jon
Hi, I'm struggling with steel beams, can anyone help. I've drawn a series of beams at an angle and grouped them together. When I try and mirror them they duplicate but the angle stays the same. (i've also grouped the referrence plane) any ideas please? (see attached) done in revit 8 - try and mirror in Site view along the green centre line. Jon
Thu, Jul 28, 2005 at 6:13:56 PM | RE: Steel Beams
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
They are associated to the workplane and when mirrored they simply just mirror and remain on there workplane. You would be best drawing one on the other work plane and copying that on the side to match... Nothing attached...?
Thu, Aug 4, 2005 at 8:46:03 AM | RE: Steel Beams
jon
The attachment was too big, that's why it didn't go. Thanks for the reply, got it working fine now. Cheers
Help with Steel I-Section Beams
Wed, Mar 3, 2004 at 7:13:07 AM
Aligning top of column to top of beams that are set out by bottom of steel
Thu, Dec 12, 2013 at 12:35:41 PM
connecting steel beams
Thu, Apr 8, 2010 at 9:33:24 AM
sloped steel?
Thu, Apr 8, 2010 at 5:51:25 PM
Showing to steel beams in the same place on plans
Fri, Jun 14, 2013 at 11:36:26 AM
Page generation time: 0.3188
